Weird Segmentation Fault
riccardi
Hello All,
I'm running into a weird segmentation fault (forrtl: severe (174): SIGSEGV) that has left me nonplussed. I have a Data Type that stores a bunch of complex vectors, dimension = 3, and a simple subroutine for printing a 3D complex wavevectors. Looping over each vector in the data type, if I send the vector to the subroutine via the data type, it fails; if I copy the data type vector it into another complex vector(3) and send that, it works.
! THIS FAILS
do i = 1, branches%natoms
call z_onebythree_print(branches%branch(1)%atdisp(i)%zvec)
end do
! THIS WORKS
zvec = branches%branch(1)%atdisp(i)%zvec
call z_onebythree_print(zvec)
end do
subroutine z_onebythree_print(zvec)
complex(kind=8), intent(in) :: zvec(3)
character(len=1) :: xchar,ychar,zchar
xchar="+"
ychar="+"
zchar="+"
if(dimag(zvec(1)).lt. zero) xchar = "-"
if(dimag(zvec(2)).lt. zero) ychar = "-"
if(dimag(zvec(3)).lt. zero) zchar = "-"
print '(F10.4,a1,F6.4,a1,F10.4,a1,F6.4,a1,F10.4,a1,F6.4,a1)',&
dble(zvec(1)),xchar,abs(dimag(zvec(1))), "i", &
dble(zvec(2)),ychar,abs(dimag(zvec(2))), "i", &
dble(zvec(3)),zchar,abs(dimag(zvec(3))), "i"
end subroutine
Please let me know if you have any ideas!
Thank you.
Demian
Ron_Green
You did read the various threads on this forum for sigsegv, segmentation fault, etc, right? And you tried ALL the options mentioned?
What version of the compiler are you using? I cannot reproduce this with 11.0 on Mac OS X. Below is my testcase. I highly recommend the previous suggestions on this post regarding
-gen-interfaces -warn interfaces
and also options
-check all -g -traceback -O2 -fp-stack-check
Something is different with your code that is not captured with the case below. If you disagree, please open a problem report at premier.intel.com including your code and instructions on how to run it.
--- repro.f90 ---
program repro
implicit none
complex (kind=8) :: zvec(3)
type zztopvec
end type
type attilla
type (zztopvec) :: atdisp(3)
end type attilla
type immabranch
type (attilla) :: branch(3)
end type
type (immabranch) :: branches
integer :: i
print*, "entering case 1"
do i=1,3
end do
print*, "exiting case 1 OK"
print*, " "
print*, "entering case 2"
do i=1,3
call z_onebythree_print( zvec )
end do
print*, "exiting case 2 OK"
contains
print*, "made it into sub"
end subroutine z_onebythree_print
end program repro
--- end file ---
output
rwgreen-mac01:63141 rwgreen$ ifort -o repro -g -traceback repro.f90
rwgreen-mac01:63141 rwgreen$ ./repro
entering case 1
made it into sub
made it into sub
made it into sub
exiting case 1 OK
entering case 2
made it into sub
made it into sub
made it into sub
riccardi
You're right, I should have looked at more threads first as before you responded I did find some useful suggestions. I still haven't found the answer though.
10.0
and also options
I'm getting ald: fatal error in /usr/bin/ld64 with the -g.. I'm going to talk to the admin
--- repro.f90 ---
program repro
implicit none
type zztopvec
end type
type attilla
end type attilla
type immabranch
end type
integer :: i
do i=1,3
end do
print*, " "
do i=1,3
end do
contains
end program repro
--- end file ---
output
entering case 1
made it into sub
made it into sub
made it into sub
exiting case 1 OK
entering case 2
made it into sub
made it into sub
made it into sub
Thank you for this suggestion! I adjusted this code so that it was more like my datatypes (with allocatable arrays and whatnot), and I was unable to reproduce the error as well (even with giant branch and atdisp arrays). There must be something funky in my code. I'm going to take another look.
Thanks for your helpful comments.
Sincerely,
Demian
riccardi
Hello again,
I have a simple code (posted below) that reproduces the problem. There are two types, seg and noseg: type seg has two entries (zvec(3) and vec(3)) while noseg has only zvec(3). The two subroutines (nosegfault and segfault differ only in the data type used). Apparantly, having the vec(3) but not using it causes the segfault, and I don't understand why. I am using v10.I also compiled this code with gfortran (version 4.2) and there is no seg fault. Thank you in advance for any insights!
Sincerely,
Demian
program repro
implicit none
type :: seg
complex(kind=8) :: zvec(3)
real(kind=8) :: vec(3)
end type seg
type :: noseg
end type noseg
print *, "run with type noseg"
call nosegfault()
print *, "run with type seg"
call segfault()
contains
subroutine segfault()
type(seg), allocatable :: wide(:)
complex (kind=8),allocatable :: long(:)
real(kind = 8) :: rval, ival
integer :: i,j, nlength_wide,nlength_long
nlength_wide = 92
nlength_long = nlength_wide * 3
allocate(wide(nlength_wide), stat=i)
allocate(long(nlength_long), stat=i)
do i = 1, nlength_long
long(i) = cmplx(0.0d0,0.0d0,kind=8)
end do
j = 1
do i = 1, nlength_wide
wide(i)%zvec(1) = long(j)
wide(i)%zvec(2) = long(j+1)
wide(i)%zvec(3) = long(j+2)
j = j + 3
end do
do i=1,nlength_wide
call z_onebythree_print(wide(i)%zvec)
end do
end subroutine
subroutine nosegfault()
type(noseg), allocatable :: wide(:)
nlength_wide = 92
end do
j = 1
j = j + 3
end do
do i=1,nlength_wide
end do
end subroutine
real(kind=8) :: zero
zero = 0.0d0
xchar="+"
ychar="+"
zchar="+"
end subroutine
end program repro
Ron_Green
Strange, I used several 10.0 compilers, including a really old version 10.0.012. No seg fault.
Are you sure you tried compiling with -heap-arrays? And what is the output of:
ulimit -a
(the value for your stack ?)
output:
$ ifort -o repronew repronew.f90
[rwgreen@spd20 rwgreen]$ ./repronew
run with type noseg
0.0000+0.0000i 0.0000+0.0000i 0.0000+0.0000i
run with type seg
riccardi
Thank you for trying. I'm glad to see that it should work, but this is indeed weird. I did try -heap-arrays, and my stack size is65532kbytes. I have a feeling that it may be something unique to my machine. I tried it with version 8.1 on an older linux server running red hat 9 and it worked fine. As soon as my admin comes back from a trip, I'll see if she can help.
Demian
Ron_Green
a few last parting thoughts:
If you use a batch system like PBS or LSF to submit jobs, be aware that under some batch subsystem your user environment may or may not be inherited by the child processes spawned on the remote nodes. Check into this (submit a batch job that simply returns the results of 'env'). This includes the stacksize.
Since you did mention using 10.0, check the ReleaseNotes in your "doc" subdirectory where the compiler is installed. This will have a list of the supported Linux distributions and releases. 10.0 is a little old, and there have been a lot of linux releases since 10.0 was released. I would worry about new linux releases running this older 10.0 compiler. If you tell me your OS distro and release ( OpenSUSE 11.0 for example, or Fedora Core 10) I could try this again with this distro and compiler. Or ask your admin to install the latest 11.0 compiler.
good hunting!
ron
