29642 Discussions
What does Intel ifort code coverage tool do to object files?
DataScientist
Valued Contributor I
When compiling source files for code coverage, a few compiler flags must be passed, like, -prof-gen. Do these code coverage flags also change the object files in any way? In other words, can I use the generated object files during the code-coverage compilation process to link and release the target library for production?
Steve_Lionel
No - the object files contain calls to PGO routines that write out a file with records of which "basic blocks" of code were entered. PGO uses this for optimization, Code Coverage uses it for.. code coverage. You would not want this in production code.
Steve_Lionel
