What is proper syntax for DLL calls
Brian_Murphy
New Contributor II
In fortran I have subroutine HSEALH_2010() !DEC$ ATTRIBUTES DLLEXPORT :: HSEALH_2010 I have been successful calling this from Excel visual basic if the subroutine has no arguments, but I can't get it to work with any arguments. Can someone give me an example or two of how to do this with arguments? Thanks, Brian in Austin, Texas
You need STDCALL, REFERENCE and ALIAS:
!DEC$ ATTRIBUTES DLLEXPORT,STDCALL,REFERENCE,ALIAS:"HSEALH_2010" :: HSEALH_2010
STDCALL is needed because VB/VBA uses it. WIthout that, you can corrupt the stack if you have arguments. REFERENCE is needed to offset the default pass-by-value of STDCALL.  ALIAS is needed to set the name you'll use from VBA.
There is a worked example provided called, of all things, EXCEL, under MixedLanguage. I suggest you study it.
Brian_Murphy
New Contributor II
I see!, said the blind man. That was exactly what I needed, and it now works perfectly. Thanks for the tip about the EXCEL sample project. It shows how to pass a string to fortran and I didn't know how to do that. That will come in handy. Cheers, Brian
