29386 Discussions
Where is the compiler binary in composer XE 2015?
eudoxos
I downloaded the trial version of Composer XE 2015.1.133. The webpage said it also included fortran compiler. I am unable to locate ifp or ifort anywhere in the package. Am I overlooking something obvious? Or is the compiler called something else? Thanks for any hints.
By default it installs into /opt/intel  You need to "source /opt/intel/bin/ifortvars.sh intel64" (to build for x64) to make the ifort command available. See the compiler release notes for more details.
eudoxos
Sorry for late reply, I don't see anything fortran-related in my installation unfortunately:
$ find /opt/intel -name 'ifort*'
Just to make sure:
$ ls /opt/intel/composer_xe_2015.2.164/bin/intel64
codecov            icc.cfg        icpc_libFNP.so  libiml_attr.so         map_opts         profdcg    tselect_libFNP.so
codecov_libFNP.so  icc_libFNP.so  inspxe-inject   libintelremotemon.so   mcpcom           profmerge  xiar
gdb-ia             icpc           inspxe-runsc    loopprofileviewer.csh  mic_extract      proforder  xild
icc                icpc.cfg       inspxe-wrap     loopprofileviewer.sh   offload_extract  tselect
$ ls /opt/intel/composer_xe_2015.2.164/bin/intel64_mic
codecov  icc      icpc      libiml_attr.so        map_opts  profdcg    proforder  x86_64-linux.env  xiar.cfg  xild.cfg
gdb-mic  icc.cfg  icpc.cfg  libintelremotemon.so  mcpcom    profmerge  tselect    xiar              xild
DId I mess up the compiler suite I need? The Parallel Studio XE page https://software.intel.com/en-us/intel-parallel-studio-xe mentions fortran for all the editions available.
I did not clarify before: I need icc and ifort targetting MIC, for cross-compilation.
TimP
Parallel studio is offered with Fortran alone, c++ without Fortran, or both together. Normally, you would select the installation option to choose components so would see which are included.  Apparently you installed c++ but not Fortran.  Each of the Xeon compilers installs the Mic cross compiler unless you deselect it.
