29386 Discussions
Why aren't new source files automatically included?
WSinc
I noticed that when I am working in a NEW project, and I compile a NEW source file, the Visual Studio does not recognize it.
I have to specifically say "move into" and then give the project name before it gets included as a new file.
This is just a minor annoyance, but this was not required before.
Why do they keep making it harder to use?
jimdempseyatthecove
The SOP for adding a new file to a project is to use the VS solution explorer, open the project, right-click on Source Files, select Add New.
The SOP for adding an existing file, that is not currently in a project, is to use the VS solution explorer, open the project, right-click on Source Files, select Add Existing. Note, the existig file can be anywhere reachable by the computer (it need not be in the project folder).
You can also add as existing file a .obj or .lib
Jim Dempsey
It's been required since VS2002 - a file has to be in a project in order to compile.
