29433 Discussions
Why can't a variable have both the PARAMETER and TARGET attributes?
OP1
New Contributor III
I am wondering why these two attributes are not compatible with each other. For instance, I may want to define a series of constants in a module, and then have various pointers point at them.
It's not really a big deal - the only thing is that not declaring my constants as PARAMETERS leave them exposed to potential (erroneous) change of values by the users of my subroutines in their code.
Olivier
A PARAMETER is not a variable. It is a "named constant". This is not the same as C's "const". You can't point at a constant. You could declare a variable with an initial value and declare it PROTECTED, but if it was a target that would not prevent the value from being changed.
