29652 Discussions
Why do Functions and Subroutines compile differently?
scriabin3
Please help me understand this:
MAIN program "contains" routines F1 and F2. MAIN calls F1 which in turn calls F2.
If F1 and F2 are Subroutines, then the program compiles and runs just fine. But if F1 and F2 are Functions, then the program gives a compilation error: Undefined symbols: "_F2_", referenced from: _MAIN__
In the latter case, what do I need to do to make the compiler "see" F2?
Here are example programs that display the above behavior:
program test1
real :: x,a1
x=5.
call f1(x,a1)
print*, a1
contains
subroutine f1(x,a1)
real, intent(in) :: x
real, intent(out) :: a1
call f2(x,a1)
end subroutine f1
subroutine f2(x,a1)
a1=2.*x
end subroutine f2
end program test1
program test2
real :: x,a1
x=5.
a1=f1(x)
print*, a1
contains
function f1(x)
real :: f1,f2
f1=f2(x)
end function f1
function f2(x)
real :: f2
f2=2.*x
end function f2
end program test2
mecej4
In the second program, the one which uses functions f1 and f2, replace
real:: f1,f2
by
real :: f1
and run the program. Then, read the manuals on the topic of "host-association".
What happens is that in the body of internal function f1(x), the declaration of f2 as real overwrites the host-association of f2. Since f2 is already available and its attributes are known to the compiler by host-association, a redeclaration of f2 as real tells the compiler to override the previous instance of f2.
forcpp
Interestingly your both versions of the same code work fine with gfortran. Also if we write the second code like below, we get the right result by ifort too.
[fortran]program test2
  real :: x,a1
  real, external :: f1
  x=5.
  a1=f1(x)
  print*, a1
end program test2
  function f1(x)
    real :: f1,f2
    f1=f2(x)
  end function f1
  function f2(x)
    real :: f2
    f2=2.*x
  end function f2[/fortran]
mecej4
real:: f1,f2
by
real :: f1
scriabin3
Thank you! So obvious, after your explanation.
