This projectI am doing now usually builds in less than a minute.
Its not very large, maybe 12-15 routines MAX.
But sometimes for no apparent reson, it takes over 20 minutes.
Why would the SAME project be inconsistent with itself?
I turned off the spyware detector, but that has no effect.
could anything lese be causing this?
Is there one file in particular that takes a long time to compile, or are all the compiles slow when this happens? Rather than a spyware detector, you might want to try disabling antivirus protection, though I doubt it would slow down things that much.
The compiles aren't hanging anyhing up.
Usually a complete rebuild compiles everything in less than a minute,
but the LINK step is what's hanging up.
This occurs about 10 percent of the time.
Just enought to really be annoying ...
and then I get, "failed to write manifest" whatever that means.
I have seen this too in VS2008 but not as often as 10%. If you hit Ctrl+Break and then re-start the build, does it go quick again?
sounds similar to what I have,
but I didn't get any error.
Ctl + Break sometimes does it more quickly.
But I have to kill the VS entirely, then start from scratch.
What does it mean:
"Can't write manifest ?"
The compiles take no time at atll. It's the LINK step that hangs up.
I'm not within the evaluation license, I just bought another year's supoort.
What does it mean:
