Win32 code faster than X64
meow
I have two identical codes (matrix multiplications and a solution of a linear system of equations) running on a Win32 (on windows vista) and the other on x64 (windows xp). Strickingly, the win32 version is a lot faster. Any clues why?
The code includes calls to routines dgetri dgetrf dgesv (see below)
Pablo
subroutine
motionstatesprueba(stateslag,statesfirstlag,w1,densidad,states,statesfirst,time)
!subroutine motionstates(SauxG,VV,SauxGp)
use
nrtype
use
mod_calibration
use
matrix_calibration
use
particle_calibration
real (dp), dimension(nx-nshk,1), intent
(in) :: stateslag,statesfirstlag
integer, intent
(in) :: time
integer
:: i, ii, info, lwork
real (dp), dimension(nshk-nshkw2), intent
(in) :: w1
(nnp12,ny) :: Caux
(nshk-nshkw1,nshk-nshkw1) :: pabloB, pabloBsave, Bfact, work, pabloBaux
(nshk-nshkw1,1) :: pabloA,pabloAsave,pabloAsave2
(nshk-nshkw1,1) :: solw2,ruido
(1,nx) :: tSauxG
(nx,1) :: SauxG
(1,1) :: data1, data2, data3, data4, data5, mas
(nx-nshkw2,1) :: myvariables_without_w2
(nnx21,1) :: myvariables_without_w21,myvariables_without_w21_first
(1,nx-nshkw2) :: tmyvariables_without_w2
(1,nnx21) :: tmyvariables_without_w21
real
(dp) :: uphi, umu, ue, ud, ua, jacob,det1
real
(dp) :: matrix_mul, produ, dete
integer, dimension
(nshkw2) :: ipiv, ipvt
(out) :: states,statesfirst
real (dp), intent
(out) :: densidad
!!!!! CHECK WHETHER stateslag(2,1)-sigmamus OR stateslag(2,1)
!!!!! i think is should be just stateslag(2,1) as the state is in log deviation
!!!!! check at the end too
!!!!! WARNING: FUNCTION PRODU ONLY WORKS FOR MATRIX 21x1
! stateslag=sigphilag, sigmulag, sigelag, sigdlag, sigalag, philag, dlag,
! ylag, xlag, pilag, clag, wlag, vwlag, vlag, k, Rlag, lambda
! w1 = uphi, umu, ue, ud, ua
! 0. Initialize some matrices
pabloB = 0_dp
pabloA = 0_dp
! 1. Get Data
call
drnnor(5, ruido)
data1(1:1,1) = ourdata(time:time,1)
data2(1,1) = ourdata(time,2)
data3(1,1) = ourdata(time,3)
data4(1,1) = ourdata(time,4)
data5(1,1) = ourdata(time,5)
!myvariables_without_w2(1:nshkw1,1) = w1
!myvariables_without_w2(nshkw1+1:nx-nshkw2,1) = stateslag(:,1)
!tmyvariables_without_w2=transpose(myvariables_without_w2)
! 2. Format matrices for faster multiplication
myvariables_without_w21(1:nshkw1,1) = w1
myvariables_without_w21(nshkw1+1:nnx21,1) = stateslag(1:nx-nshkw-1,1)
myvariables_without_w21_first(1:nshkw1,1) = w1
myvariables_without_w21_first(nshkw1+1:nnx21,1) = statesfirstlag(1:nx-nshkw-1,1)
tmyvariables_without_w21=
transpose
(myvariables_without_w21)
! 3. Assign w1 errors
uphi=w1(1)
umu=w1(2)
ue=w1(3)
ud=w1(4)
ua=w1(5)
! 4. Law of motions for observables
! 4.1 Relative price of investment
pabloA(1:1,1:1) = (data1(1,1) + meanmu - (produ(psi1obs1_without_w21,myvariables_without_w21,nnx21)+ &
0.5_dp*(matrix_mul(psi2obs1_without_w21,myvariables_without_w21_first,nnx21)+psi2obs1(nx,nx))))
! pabloA(1:1,1:1) = (data1(1,1) - meanmu - (produ(psi1obs1_without_w21,myvariables_without_w21,nnx21)))
pabloB(1,2) = psi2obs1(7,2)*umu
! 4.2 Nominal interest rate
pabloA(2:2,1:1) = (data2(1,1) - bigrs - (produ(psi1obs2_without_w21,myvariables_without_w21,nnx21)+ &
0.5_dp*(matrix_mul(psi2obs2_without_w21,myvariables_without_w21_first,nnx21)+psi2obs2(nx,nx))))
pabloB(2,1) = psi2obs2(6,1)*uphi
pabloB(2,2) = psi2obs2(7,2)*umu
pabloB(2,3) = psi2obs2(8,3)*ue
pabloB(2,4) = psi2obs2(9,4)*ud
pabloB(2,5) = psi2obs2(10,5)*ua
! inflation
pabloA(3:3,1:1) = (data3(1,1) - pis - (produ(psi1obs3_without_w21,myvariables_without_w21,nnx21)+&
0.5_dp*(matrix_mul(psi2obs3_without_w21,myvariables_without_w21_first,nnx21)+psi2obs3(nx,nx))))
pabloB(3,1) =psi2obs3(6,1)*uphi
pabloB(3,2) =psi2obs3(7,2)*umu
pabloB(3,3) =psi2obs3(8,3)*ue
pabloB(3,4) =psi2obs3(9,4)*ud
pabloB(3,5) =psi2obs3(10,5)*ua
! output
pabloA(4:4,1:1) = data4(1,1) -
log
(growth) - (produ(psi1obs4_without_w21,myvariables_without_w21,nnx21)+&
0.5_dp*(matrix_mul(psi2obs4_without_w21,myvariables_without_w21_first,nnx21)+psi2obs4(nx,nx)))
pabloB(4,1) = psi2obs4(6,1)*uphi
pabloB(4,2) = psi2obs4(7,2)*umu
pabloB(4,3) = psi2obs4(8,3)*ue
pabloB(4,4) = psi2obs4(9,4)*ud
pabloB(4,5) = psi2obs4(10,5)*ua
! real wage
pabloA(5:5,1:1) = data5(1,1) -
log
(growth) - (produ(psi1obs5_without_w21,myvariables_without_w21,nnx21)+&
0.5_dp*(matrix_mul(psi2obs5_without_w21,myvariables_without_w21_first,nnx21)+psi2obs5(nx,nx)))
pabloB(5,1) = psi2obs5(6,1)*uphi
pabloB(5,2) = psi2obs5(7,2)*umu
pabloB(5,3) = psi2obs5(8,3)*ue
pabloB(5,4) = psi2obs5(9,4)*ud
pabloB(5,5) = psi2obs5(10,5)*ua
! write(14,'(5F10.6)') pabloA
! write(14,'(5F12.6)') pabloB(1,:)
! write(14,'(5F12.6)') pabloB(2,:)
! write(14,'(5F12.6)') pabloB(3,:)
! write(14,'(5F12.6)') pabloB(4,:)
! write(14,'(5F12.6)') pabloB(5,:)
! compute w2
! order in solw2
! solw2(1) = usigphi, solw2(2) = usigmu, solw2(3) = usige, solw2(4) = usigd, solw2(5) = usiga
pabloAsave=pabloA
pabloBsave=pabloB
! faster code to solve system; set dynamic library in project; linker; input
call
DGESV (nshkw2,1,pabloB,nshkw2,ipiv,pabloA,nshkw2,info)
solw2 = pabloA
! write(14,'(5F16.4)') solw2
! do i = 1,nshk-nshkw1
! enddo
pabloAsave2=
matmul
(pabloBsave,solw2)
!if (info.ne.0) then
! pabloA = 10000_dp
!endif
! compute jacobian for likelihood
lwork = nshkw2
call
DGETRI (nshkw2,pabloB,nshkw2,ipiv,work,lwork,info)
call
DGETRF (nshkw2,nshkw2,pabloB,nshkw2,ipvt,info)
! dete = 0_dp
!else
dete = 1_dp
do
i = 1,nshkw2
if (ipvt(i).ne.i)
then
dete = -dete * pabloB(i,i)
else
dete = dete * pabloB(i,i)
endif
end do
!endif
jacob =
abs
(dete)
!write(14,'(F16.10)') jacob
!pause
! assamble complete state
!solw2(1,1) = 1_dp
!solw2(2,1) = -1_dp
!solw2(3,1) = 0.1_dp
!solw2(4,1) = -0.2_dp
!solw2(5,1) = 0.001_dp
! second order
states(8:8,1:1) = produ(psi1y_without_w21,myvariables_without_w21,nnx21)&
+0.5_dp*(matrix_mul(psi2y_without_w21,myvariables_without_w21_first,nnx21)+ psi2y(nx,nx)) + psi2y(6,1)*uphi*solw2(1,1) &
+ psi2y(7,2)*umu*solw2(2,1) + psi2y(8,3)*ue*solw2(3,1) + psi2y(9,4)*ud*solw2(4,1) + psi2y(10,5)*ua*solw2(5,1)
states(16:16,1:1) = produ(psi1bigr_without_w21,myvariables_without_w21,nnx21)&
+0.5_dp*(matrix_mul(psi2bigr_without_w21,myvariables_without_w21_first,nnx21) + psi2bigr(nx,nx)) + psi2bigr(6,1)*uphi*solw2(1,1) &
+ psi2bigr(7,2)*umu*solw2(2,1) + psi2bigr(8,3)*ue*solw2(3,1) + psi2bigr(9,4)*ud*solw2(4,1) + psi2bigr(10,5)*ua*solw2(5,1)
states(15:15,1:1) = produ(psi1k_without_w21,myvariables_without_w21,nnx21) &
+0.5_dp*(matrix_mul(psi2k_without_w21,myvariables_without_w21_first,nnx21) + psi2k(nx,nx)) + psi2k(6,1)*uphi*solw2(1,1) &
+ psi2k(7,2)*umu*solw2(2,1) + psi2k(8,3)*ue*solw2(3,1) + psi2k(9,4)*ud*solw2(4,1) + psi2k(10,5)*ua*solw2(5,1)
states(14:14,1:1) = produ(psi1v_without_w21,myvariables_without_w21,nnx21) &
+0.5_dp*(matrix_mul(psi2v_without_w21,myvariables_without_w21_first,nnx21)+ psi2v(nx,nx)) + psi2v(6,1)*uphi*solw2(1,1) &
+ psi2v(7,2)*umu*solw2(2,1) + psi2v(8,3)*ue*solw2(3,1) + psi2v(9,4)*ud*solw2(4,1) + psi2v(10,5)*ua*solw2(5,1)
states(13:13,1:1) = produ(psi1vw_without_w21,myvariables_without_w21,nnx21) &
+0.5_dp*(matrix_mul(psi2vw_without_w21,myvariables_without_w21_first,nnx21) + psi2vw(nx,nx)) + psi2vw(6,1)*uphi*solw2(1,1) &
+ psi2vw(7,2)*umu*solw2(2,1) + psi2vw(8,3)*ue*solw2(3,1) + psi2vw(9,4)*ud*solw2(4,1) + psi2vw(10,5)*ua*solw2(5,1)
states(12:12,1:1) = produ(psi1w_without_w21,myvariables_without_w21,nnx21) &
+0.5_dp*(matrix_mul(psi2w_without_w21,myvariables_without_w21_first,nnx21) + psi2w(nx,nx)) + psi2w(6,1)*uphi*solw2(1,1) &
+ psi2w(7,2)*umu*solw2(2,1) + psi2w(8,3)*ue*solw2(3,1) + psi2w(9,4)*ud*solw2(4,1) + psi2w(10,5)*ua*solw2(5,1)
states(11:11,1:1) = produ(psi1c_without_w21,myvariables_without_w21,nnx21) &
+0.5_dp*(matrix_mul(psi2c_without_w21,myvariables_without_w21_first,nnx21) + psi2c(nx,nx)) + psi2c(6,1)*uphi*solw2(1,1) &
+ psi2c(7,2)*umu*solw2(2,1) + psi2c(8,3)*ue*solw2(3,1) + psi2c(9,4)*ud*solw2(4,1) + psi2c(10,5)*ua*solw2(5,1)
states(10:10,1:1) = produ(psi1pi_without_w21,myvariables_without_w21,nnx21) &
+0.5_dp*(matrix_mul(psi2pi_without_w21,myvariables_without_w21_first,nnx21) + psi2pi(nx,nx)) + psi2pi(6,1)*uphi*solw2(1,1) &
+ psi2pi(7,2)*umu*solw2(2,1) + psi2pi(8,3)*ue*solw2(3,1) + psi2pi(9,4)*ud*solw2(4,1) + psi2pi(10,5)*ua*solw2(5,1)
states(9:9,1:1) = produ(psi1x_without_w21,myvariables_without_w21,nnx21) &
+0.5_dp*(matrix_mul(psi2x_without_w21,myvariables_without_w21_first,nnx21) + psi2x(nx,nx))+ psi2x(6,1)*uphi*solw2(1,1) &
+ psi2x(7,2)*umu*solw2(2,1) + psi2x(8,3)*ue*solw2(3,1) + psi2x(9,4)*ud*solw2(4,1) + psi2x(10,5)*ua*solw2(5,1)
states(17:17,1:1) = 1.0_dp
states(5:5,1:1) = rhosigmaa*stateslag(5,1) + netaa*solw2(5,1)
states(4:4,1:1) = rhosigmad*stateslag(4,1) + netad*solw2(4,1)
states(3:3,1:1) = rhosigmae*stateslag(3,1) + netae*solw2(3,1)
states(2:2,1:1) = rhosigmamu*stateslag(2,1) + netamu*solw2(2,1)
states(1:1,1:1) = rhosigmaphi*stateslag(1,1) + netaphi*solw2(1,1)
states(7:7,1:1) = rhod*stateslag(7:7,1:1)+(2.71828182846_dp)**(sigmads)*ud+&
0.5_dp*(2*(2.71828182846_dp)**(sigmads)*rhosigmad*ud*statesfirstlag(4:4,1:1)+&
2*(2.71828182846_dp)**(sigmads)*netad*ud*solw2(4,1))
states(6:6,1:1) = rhocurlyphi*stateslag(6:6,1:1)+(2.71828182846_dp)**(sigmaphis)*uphi+&
0.5_dp*(2*(2.71828182846_dp)**(sigmaphis)*rhosigmaphi*uphi*statesfirstlag(1:1,1:1)+&
2*(2.71828182846_dp)**(sigmaphis)*netaphi*uphi*solw2(1,1))
! first order
statesfirst(8:8,1:1) = produ(psi1y_without_w21,myvariables_without_w21_first,nnx21)
statesfirst(16:16,1:1) = produ(psi1bigr_without_w21,myvariables_without_w21_first,nnx21)
statesfirst(15:15,1:1) = produ(psi1k_without_w21,myvariables_without_w21_first,nnx21)
statesfirst(14:14,1:1) = produ(psi1v_without_w21,myvariables_without_w21_first,nnx21)
statesfirst(13:13,1:1) = produ(psi1vw_without_w21,myvariables_without_w21_first,nnx21)
statesfirst(12:12,1:1) = produ(psi1w_without_w21,myvariables_without_w21_first,nnx21)
statesfirst(11:11,1:1) = produ(psi1c_without_w21,myvariables_without_w21_first,nnx21)
statesfirst(10:10,1:1) = produ(psi1pi_without_w21,myvariables_without_w21_first,nnx21)
statesfirst(9:9,1:1) = produ(psi1x_without_w21,myvariables_without_w21_first,nnx21)
statesfirst(17:17,1:1) = 1.0_dp
statesfirst(5:5,1:1) = rhosigmaa*statesfirstlag(5,1) + netaa*solw2(5,1)
statesfirst(4:4,1:1) = rhosigmad*statesfirstlag(4,1) + netad*solw2(4,1)
statesfirst(3:3,1:1) = rhosigmae*statesfirstlag(3,1) + netae*solw2(3,1)
statesfirst(2:2,1:1) = rhosigmamu*statesfirstlag(2,1) + netamu*solw2(2,1)
statesfirst(1:1,1:1) = rhosigmaphi*statesfirstlag(1,1) + netaphi*solw2(1,1)
statesfirst(7:7,1:1) = rhod*statesfirstlag(7:7,1:1)+(2.71828182846_dp)**(sigmads)*ud
statesfirst(6:6,1:1) = rhocurlyphi*statesfirstlag(6:6,1:1)+(2.71828182846_dp)**(sigmaphis)*uphi
! compute density
! print *, 'jacob',jacob
densidad = jacob*(2.71828182846_dp)**(-(solw2(1,1)**2+solw2(2,1)**2+solw2(3,1)**2+solw2(4,1)**2+solw2(5,1)**2)/2)/(2*pi)**(nshkw2/2)
!densidad = (2.71828182846_dp)**(-(solw2(1,1)**2+solw2(2,1)**2+solw2(3,1)**2+solw2(4,1)**2+solw2(5,1)**2)/2)/(2*pi)**(nshkw2/2)
! write(14,'(5F10.8,2F16.6)') solw2,densidad,jacob
!open (unit=14, file='pabloBsave.txt',status='replace',action='write')
! write(14,*) pabloBsave
!close (unit = 14)
!open (unit=14, file='pabloAsave.txt',status='replace',action='write')
! write(14,*) pabloAsave
!close (unit = 14)
end subroutine
motionstatesprueba
TimP
Your example is near impossible to read (note the pencil tool for code insertion).I don't think you mentioned your compile options. If you are spending more time in you own code than in MKL, and you have mixed single and double precision, ifort 32-bit has more efficient options for that than ifort 64-bit for 64-bit Windows does.
Steve_Nuchia
Sounds like a job for VTune. Get samplling results for both, see if the hotspot distribution is roughly the same. The decision tree gets a lot less bushy once we know the results of the basic profiling runs.
