Windows application ERROR
efemelih
I am using VStudio.net. While building windows application ide gives following error.
"winapp1.exe missing"
WinApp1 : error PRJ0019: A tool returned an error code
Thanks....
Message Edited by efemelih on 01-19-2006 08:50 AM
The screen capture suggests that the Intel Fortran integration did not install correctly, but I see nothing related to your WinApp1 build problem. Examining the build log may be helpful.
efemelih
buildlog message;
Generating Fortran include file...
deftofd "C:Documents and SettingsAli YlmazBelgelerimVisual Studio ProjectsWinApp1Resource.h" "C:Documents and SettingsAli YlmazBelgelerimVisual Studio ProjectsWinApp1Resource.fd"
fpp: fatal: can't fopen file: C:Documents and SettingsAli Y
WinApp1 build failed.
not; setup repair program again and again
(English Speak:0 or -1) sorry
efemelih
errormessage .jpeg attach
I need step by step intel fortran integration incorporate vstudio.net
What version of Intel Visual Fortran are you using? It would appear that the fpp preprocessor has a problem with multinational characters in your file path, but I thought we fixed that some time ago. That is preventing the executable from being built.
To install the integration, you run the compiler install and click on the last Install or Modify button in the installer screen, then follow the prompts. I recommend uninstalling the "Intel Fortran Integration into Microsoft Visual Studio" from Add or Remove Programs and then reinstall. Be sure you are using the latest version, w_fc_c_9.0.028.
efemelih
I thought creating problems to Turkish characters .While MyDocument folder in C: driver creating problems to Turkish charecters. Else(D: or E:) no problems.
While Visual Studio Projects folder in D: or E: Driver. no probmlems. So, no problem now....
Thank you very much from Turkey...
Steve Brother;
You are very good Fortran Teacher....
Message Edited by efemelih on 01-19-2006 11:20 AM
Message Edited by efemelih on 01-19-2006 11:22 AM
