Writting data efficiently.
Ilie__Daniel
Hello!
Let's assume that I have an array with 6 elements in it and I want to write it to a direct access fixed record length file. The array size in bytes is equal to the record length.
Could you possiblyrate the following pseudo-codes from most efficient to least efficient:
1. write()array ! Writes the whole array.
2. write()array(1:6)
3. write()(array(i), i=1,6)
4. write()array(1),array(2),...,array(6)
5. write()array(1:3),array(4:6)
Thank you for your input.
3. write()array(1:3),array(4:6)
5. write()(array(i), i=1,6)
