29558 Discussions
Wrong array size with realloc_lhs when a type contains a allocatable class component
thomas_boehme
New Contributor II
We have a large F2003 code that runs fine on IVF12.1 but always caused unexpected behavior on IVF13.x (and also the beta IVF14.x).
After quite a long search, we were able to attribute the problem to a (in my understanding) incorrect behavior when automatically reallocating the LHS of an array assignment.
I have a attached a (minimal?) demonstrator for that issue. It needs to be compiled with F2003 semantics enabled (or realloc_lhs).
I would expect that both reallocated arrays (Target...) should have size 5, however, after assignment the TargetArrayWithAllocatableClass has the full size of the src, and not just the first 5 elements.
The bug also disappers when changing the class(ATYPE), ALLOCATABLE to a class(ATYPE), POINTER.
Best regards, Thomas
[fortran]
module classdefs
type :: AType
real :: dummy
end type
type :: ClassWithAllocatableClassComponent
class (AType), ALLOCATABLE :: dummy
end type
type :: ClassWithAllocatableTypeComponent
type (AType), ALLOCATABLE :: dummy
end type
type PtrToClassWithAllocatableClassComponent
type (ClassWithAllocatableClassComponent), POINTER :: ptr
end type
type PtrToClassWithAllocatableTypeComponent
type (ClassWithAllocatableTypeComponent), POINTER :: ptr
end type
end module
program AllocatableClassComponentBug
use classdefs
implicit none
! Variables
type (PtrToClassWithAllocatableClassComponent), ALLOCATABLE :: SrcArrayWithAllocatableClass(:)
type (PtrToClassWithAllocatableTypeComponent), ALLOCATABLE :: SrcArrayWithAllocatableType(:)
type (PtrToClassWithAllocatableClassComponent), ALLOCATABLE :: TargetArrayWithAllocatableClass(:)
type (PtrToClassWithAllocatableTypeComponent), ALLOCATABLE :: TargetArrayWithAllocatableType(:)
integer i
ALLOCATE(SrcArrayWithAllocatableClass(10))
ALLOCATE(SrcArrayWIthAllocatableType(10))
TargetArrayWithAllocatableClass = SrcArrayWithAllocatableClass(1:5)
TargetArrayWithAllocatableType = SrcArrayWithAllocatableType(1:5)
PRINT *, 'Expected size for both Targets is 5'
PRINT *, 'Actual size for TargetArrayWithAllocatableClass is ', size(TargetArrayWithAllocatableClass)
PRINT *, 'Actual size for TargetArrayWithAllocatableType is ', size(TargetArrayWithAllocatableType)
end program AllocatableClassComponentBug
[/fortran]
thomas_boehme
New Contributor II
I have just seen that the above issue is likely related to issue DPD200243378 posten in the Linux forum a few days ago.
IanH
For what it is worth: allocatable polymorphic components require considerable "care" when working with current/recent ifort.  I've been able to get by replacing assignments with ALLOCATE(lhs%alloc_poly_component, SOURCE=rhs%alloc_poly_component) once that was supported.  Dancing on a pin head while facing north and juggling six open bottles of wine also helps, or failing that, just drink the wine.
I put some test cases together in this thread here.
It is not entirely clear to me that this is the same as Ian's issue, I'm pretty sure it's not the 244378 issue. But there is probably some commonality here.  I will report this to the developers - thanks for the example - I decided to attach it to DPD200236021 (Ian's)
jimdempseyatthecove
IanH,
Have you posted a link of you on Youtube of you dancing on a pin head while facing north and juggling six open bottles of wine.
I'd like to see it.
Jim ;)
The developers tell me that this is not the same as the earlier issue.  New issue DPD200247184 created for this one.
thomas_boehme
New Contributor II
Steve, thanks for keeping me informed and creating the new issue.
BR, Thomas
This uncovered multiple problems, which required fixes in the compiler and run-time library. It looks as if those will get in for the October update.
