Wrong code when using OpenMP collapse
Vladimir_F_1
 i encountered a behavior I believe is a bug in ifort 14.0.2 which took me quite a lot of time to find.
  implicit integer(a-z)
  nx = 10
  ny = 10
  nz = 10
  tnx = 2
  tny = 2
  tnz = 2
  !$omp parallel do collapse(3)
  do bk = 1, nz, tnz
   do bj = 1, ny, tny
    do bi = 1, nx, tnx
     do k = bk, min(bk+tnz-1,nz)
      do j = bj, min(bj+tny-1,ny)
       do i = bi, min(bi+tnx-1,nx)
        if (i==1.and.j==1.and.k==1) print *,"*"
       end do
      end do
     end do
    end do
   end do
  end do
  !$omp end parallel do
end
This should print just one "*", but prints more of them
lada@meop37:~/f/testy/errors> ifort -openmp collapse.f90
lada@meop37:~/f/testy/errors> ./a.out
lada@meop37:~/f/testy/errors> OMP_NUM_THREADS=1 ./a.out
lada@meop37:~/f/testy/errors> OMP_NUM_THREADS=10 ./a.out
lada@meop37:~/f/testy/errors> f90 -openmp collapse.f90
f90: Warning: Optimizer level changed from 0 to 3 to support parallelized code.
Vladimir_F_1
Obviously, "private(i,j,k,bi,bj,bk)" is missing there, but that doesn't change the behavior.
pbkenned1
Hello Vladimir,
Thanks for reporting this. I'll investigate and follow up.
Patrick
pbkenned1
Straightforward defect, reported to compiler engineering with tracking ID DPD200255773.  I'll keep this thread updated with any news.
Patrick
Vladimir_F_1
Are there any news about this problem? I still can reproduce it in intel/15.0.2.164 on the Archer supercomputer. It is very annoying.
Kevin_D_Intel
Unfortunately there is no progress to report. The issue is unchanged with our latest 16.0 compiler release also. I pinged Development for some status.
