29650 Discussions
Wrong compiler error using module from submodule
Daniel_Dopico
In the following code, a submodule makes explicit USE of it's parent module.
module forces
implicit none
type force
   ! type wrongly accesed via USE statement
end type force
type force_sensib
   ! type correctly accesed via HOST ssociation
contains
   procedure,pass::fstb
end type force_sensib
interface
   module subroutine fstb(FS)
       class(force_sensib),intent(inout)::FS
   end subroutine fstb
end interface
end module forces
submodule(forces) forces_sensib
   use forces,only:force !Wrong sentence, triggering the problem.
   implicit none
contains
   module procedure fstb!(FS)
   end procedure fstb
end submodule forces_sensib
The error offered by the compiler is confusing (an wrong).
error #6115: A separate interface body must have been declared in the program unit or an ancestor of the program unit for the separate module procedure. [FSTB]
compilation aborted for ... (code 1)
Clearly the problem is not the interface to FSTB, which is present and correctly placed in the module. The problem is the USE sentence in the submodule, but the compiler is unable to detect this.
I have been experiencing similar fake errors with submodules which makes really difficult to guess which are the errors in the code.
Ron_Green
The bug ID is CMPLRLLVM-68781
Ron_Green
Clearly our error message could and should be better.  The Nag compiler gives a very intuitive message:
$ nagfor repro.f90
NAG Fortran Compiler Release 7.2(Shin-Urayasu) Build 7203
Error: repro.f90, line 22: Module FORCES USEs itself
       detected at :@FORCE
[NAG Fortran Compiler pass 1 error termination, 1 error]
I will open a bug report.
Ron_Green
Daniel_Dopico
Thank you, Ron.
What is the purpose of the bug ID? Can I suscribe to it or something?
I don't see it in my Dashboard open cases and I didn't receive any notification either.
Ron_Green
Issued entered on the Forum are not linked to your Online Service Center account.  If you want to track issue please enter them on OSC.
For bugs entered here:  I give you the bug ID as bookkeeping.  For the situation where you submit several bugs.  As those get a fix I will alert you here on the Forum.  We use an internal-only Jira issue tracking system, thus you will not be able to see the bug progress.  It would be nice if it was more open, but it's not and won't be for the foreseeable future.
Ron_Green
Another use case for the bug ID - you can ask if this bug is fixed or get a status update.
Daniel_Dopico
Thank you, Ron.
I usuallly prefer to enter the tickets myself, for example if it is an ICE, but sometimes It is helpful to get a second opinion in the forum before bothering.
