29381 Discussions
Wrong result by calling a subroutine in parallel region
dansou__anicet
#HELP #OpenMP #Fortran #Visual
I have a simple subroutine in sequential. When the subroutine is called from a parallel region, I obtain wrong results compare to results obtained when it is called from a sequential region.
I write the inputs of the subroutines from each region, they are exactly the same (sequantial or parallel). But the results are not, why ?
Thank you in advance
