29487 Discussions
Wrong result depending on order of component in DT
FlyingHermes
The following code creates wrong outputs.
! Compilation & excecution:    ifort main.f90 ; ./a.out
Module Universal_Class
  implicit none
  Type  ,abstract                 ::      Universal_Type
  End Type
End Module
Module Structure_Class
  use Universal_Class   ,only:  Universal_Type
  implicit none
  Type  ,extends(Universal_Type)  ::      Structure_Type
    character(6)                  ::      Name  =   "Empty "
    integer   ,dimension(1)       ::      ivar  =   [0]
  End Type
End Module
Program Main
  use Structure_Class   ,only:  Structure_Type
  implicit none
  type(Structure_Type) ,parameter ::  Svar    =   Structure_Type( Name="Filled",ivar=[1] )
  write(*,"('              ',a15,3x,a15)") 'Found', 'Expected'
  write(*,"('              ',a15,3x,a15)") '-----', '-----'
  write(*,"('  Svar%Name = ',a15,3x,a15)") Svar%Name, 'Filled'
  write(*,"('  Svar%ivar = ',i15,3x,i15)") Svar%ivar, 1
End Program
The outputs are:
                      Found          Expected
Svar%Name =          Filled            Filled
Svar%ivar =             256                 1
The correct outputs are obtained if either one of the following modifications is done
  • the order of the components inside the "Structure_Type" derived-type are changed
  • the inheritance is removed
I'v only tested the code with ifort version 15.0.6.
Thanks for investigating.
Thanks, this is still reproducible in 16.0.2. I find that the problem also goes away if Svar is a variable and not a PARAMETER. Escalated as issue DPD200382227.
I expect this problem to be fixed in the 17.0 compiler release.
