29374 Discussions
XE 13.0 / 13.1 Help installation bug
DavidWhite
Valued Contributor II
I have installed Update 3 over Update 2, replacing that installation, so that I only have XE 13.1 installed.
However, in MSVS Help, it has retained the Intel Fortran Composer XE 13.0 User and Reference Guide in addtion to the 13.1 version.  I assume that during the install, the previous version should have been uninstalled.
David
Thanks - I will pass this on to the developers. Which VS version are you using?
DavidWhite
Steve,
I have MSVS 2010 Pro.
I also tried removing Update 2 and repairing Update 3, but under View Help, Help 13.0 is still there.
David
