公告
XP Home install error/problems
steve_schroeder
初学者
1,283 次查看
I have a problem installing the app on Windows XP Home edition. Upon launch of install, I get a a script error preventing the html/script file from executing thus preventing an install routine.
I have countered this by running setup.exe filesvia the CD directory structure for the components that I need. (ie...the compiler, debugger, visual studio tools).
This worked with the license file, however upon starting visual studio to create a new project, there are no files associated with the named project after creating it.
I have gone through all the environment setups and this is not a visual studio error but most likely an error because of the installation procedure that I HAD to do.
Any ideas?
Thanks, Steve
0 项奖励
1 回复
Steven_L_Intel1
1,283 次查看
I'm not sure I understand what you're seeing.
When you open Visual Studio.NET, does the blue Intel "F" icon appear in the splash screen? If you select Help..About, is Intel Fortran listed as an installed component? When you go to create a new project, is Intel Fortran one of the choices for project categories?
I suspect that it would be best if we continued this through Intel Premier Support. Please attach a ZIP of your "solution" (workspace) directory and perhaps a screen shot that shows the problem.
0 项奖励
回复
