Xcode 6.2
Izaak_Beekman
New Contributor II
Is it safe to upgrade to Xcode 6.2 or will this break the installed compiler? If it is safe is there anything special I need to do?
TIA
-Zaak
Which compiler version do you have now? The latest 15.0 at the time I write this has not been tested with Xcode 6.2. Apple usually makes incompatible changes with each Xcode update, but at the very least you will need to reinstall Fortran after updating Xcode.
Izaak_Beekman
New Contributor II
Thanks for the update Steve…. Has anyone tried upgrading? I don’t particularly fancy reinstalling the compilers after upgrading only to find that they don’t work due to Xcode changes….
