Xilink Error
nick_carter
I am using the Intel Visual Fortran compiler within Microsoft Visual Studio 2005, and on linking get the error "The input line is too long..." reported from xilink. On looking at the build log the command line is extremely long. Is this a bug, and can something be done about this (e.g. a workaround)?
Nick
TimP
The usual way to get around Microsoft command line length limit is with a multi-step build. For example, link groups of objects into larger objects or libraries, then link them together. You might note that this is often done in open software, for example, in the g++ and gfortran library builds.
I recognize that this tends to defeat the convenience of Visual Studio. There, my colleagues tend to work with large source files containing many subroutines, so that the number of .obj files required stays within Microsoft limits. Others prefer to group objects into .dll each of which is under the limit.
nick_carter
Thanks. It's a shame though, as several people will be working with this project, and we never had this problem with CVF.
Please report the problem to Intel Premier Support and include what is needed to reproduce the problem.
