Zero length array constructors
IanH
  IMPLICIT NONE
  TYPE t
  END TYPE t
  TYPE(t), PARAMETER :: array(0) =
END
>ifort "2014-08-27 ZeroLength.f90"
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.0.108 Build 20140726
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
2014-08-27 ZeroLength.f90(4): error #5082: Syntax error, found '::' when expecting one of: , (/ : ]
2014-08-27 ZeroLength.f90(4): error #6592: This symbol must be a defined parameter, an enumerator, or an argument of an
inquiry function that evaluates to a compile-time constant.
compilation aborted for 2014-08-27 ZeroLength.f90 (code 1)
Hmm - I thought we had fixed that one a while ago. I'll check.
