Zero-sized array with type-spec
rudi-gaelzer
Even with version:
Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.1.144 Build 20181018
this old bug was not fixed.
Gfortran v. 8.2.1  compiles all right and gives the correct result.
Juergen_R_R
Valued Contributor II
Indeed, also Update2 of v19 has no fix for this. Both nagfor and gfortran compile this without issues, pgfortran also throws a syntax error.
Devorah_H_Intel
I will check the status of this issue.
