about ifort
yingwu
Hi, after resetting my password, I am back again.
I am learning to use command line to compile the code. So I use ifort. In my code, I need to use MKL and another library, named MATFOR. I got the problem when I specify the include path and the library path in the ifort command.
My command is
C:\>ifort test.f90 mkl.lib libguide.lib -I C:\Program Files\AnCAD\MATFOR4\include\IF9 -link C:\Program Files\AnCAD\MATFOR4\lib\IF9
However, there is error returning as below:
Intel Visual Fortran Compiler Professional for applications running on IA-32, Version 11.0 Build 20081105 Package ID: w_cprof_p_11.0.066
Copyright (C) 1985-2008 Intel Corporation. All rights reserved.
ifort: command line warning #10161: unrecognized source type 'Files\AnCAD\MATFOR4\include\IF9'; object file assumed
test.f90(6): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [FML]
use fml
test.f90(7): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [FGL]
use fgl
test.f90(144): error #6404: This name does not have a type, and must have an explicit type. [MF]
call msdisplay(mf(m1),'m1')
compilation aborted for test.f90 (code 1)
So how to add the include path? Thanks very much
TimP
Look up the ifort command line option I in the help file. It's just like every other compiler I've seen the last 20 years.
USE files would have the suffix .mod appended, so they have to be compiled (from Fortran MODULE source code) prior to their appearance in USE.
INCLUDE files must be Fortran source, in format compatible with the source file where INCLUDE appears.
