29642 Discussions
abstract class and interface problem
qiu_n_
I test abstrat class and abstract interface ,ihave a problem..
how can use  abstract interface ?,i have a example,i compile it ,but it can't run!
following is my code ,please correct my error,thank you !
!*------------------------------------------module employee_class ------------------*
type,abstract,public :: employee
  private
  character(len = 30) :: first_name
  character(len = 30) :: last_name
  character(len = 11) :: ssn
  real :: pay = 0
contains
   procedure,public :: set_employee =>set_employee_sub
   procedure,public :: set_name =>set_name_sub
   procedure,public :: set_ssn =>set_ssn_sub
   procedure,public :: set_pay =>set_pay_sub
   procedure,public :: get_first_name =>get_first_name_fn
   procedure,public :: get_last_name =>get_last_name_fn
   procedure,public :: get_ssn =>get_ssn_fn
   procedure,public :: get_pay =>get_pay_fn
   procedure(calc_payx),public,nopass,deferred :: calc_pay
end type employee
abstract interface
real function calc_payx(hours,rate)
   implicit none
   real,intent(in) :: hours
   real,intent(in) :: rate
end function calc_payx
!real function calc_payy(salary)
!   implicit none
!   real,intent(in) :: salary
!end function calc_payy
end interface
private :: set_employee_sub,set_name_sub,set_ssn_sub,set_pay_sub
private :: get_first_name_fn,get_last_name_fn,get_ssn_fn
private :: get_pay_fn
contains
subroutine set_employee_sub(this,first,last,ssn)
implicit none
class(employee) :: this
character(len=*) ,intent(in) :: first
character(len=*) ,intent(in) :: last
character(len=*) ,intent(in) :: ssn
this%first_name = first
this%last_name = last
this%ssn = ssn
this%pay = 0
end subroutine set_employee_sub
subroutine set_name_sub(this,first,last)
implicit none
character(len=*),intent(in) :: first
character(len=*),intent(in) :: last
end subroutine set_name_sub
subroutine set_ssn_sub(this,ssn)
implicit none
character(len=*),intent(in) :: ssn
this%ssn = ssn
end subroutine set_ssn_sub
subroutine set_pay_sub(this,pay)
implicit none
real,intent(in) :: pay
this%pay = pay
end subroutine set_pay_sub
character(len = 30) function get_first_name_fn(this)
   implicit none
   get_first_name_fn = this%first_name
end function get_first_name_fn
character(len = 30) function get_last_name_fn(this)
   implicit none
   get_last_name_fn = this%last_name
end function get_last_name_fn
character(len = 11) function get_ssn_fn(this)
   implicit none
   get_ssn_fn = this%ssn
end function get_ssn_fn
real function get_pay_fn(this)
   implicit none
   get_pay_fn = this%pay
end function get_pay_fn
!real function calc_pay_fn(this,hours)
!   implicit none
!   class(employee) :: this
!   real,intent(in) :: hours
!   calc_pay_fn = 0
!end function calc_pay_fn
end module  employee_class
!*------------------------------------------module salaried_employee_class ------------------*
use employee_class
implicit none
type,public,extends(employee) :: salaried_employee
   private
   real :: salary = 0
   contains
   procedure,public :: set_salary => set_salary_sub
   procedure,public,nopass:: calc_payx => calc_pay
end type salaried_employee
private :: set_salary_sub,calc_payx
contains
subroutine set_salary_sub(this,salary)
implicit none
class(salaried_employee) :: this
call this%set_pay(salary)
this%salary = salary
end subroutine set_salary_sub
real function calc_pay(hours,rate)
implicit none
!class(salaried_employee) :: this
   calc_pay = hours *rate
!call this%set_pay(hours)
end module  salaried_employee_class
!*------------------------------------------module hourly_employee_class ------------------*
use employee_class
implicit none
type,public,extends(employee) :: hourly_employee
   private
   real :: rate = 0
   contains
   procedure,public :: set_pay_rate => set_pay_rate_sub
   procedure,public,nopass :: calc_payx => calc_pay
end type hourly_employee
private :: set_pay_rate_sub,calc_pay
contains
subroutine set_pay_rate_sub(this,rate)
implicit none
  class(hourly_employee) :: this
this%rate = rate
end subroutine set_pay_rate_sub
implicit none
!class(hourly_employee) :: this
  real :: daypay
  calc_pay = hours*rate*1.5
end module  hourly_employee_class
program test_employee
   use hourly_employee_class
   use salaried_employee_class
   implicit none
   type(salaried_employee),pointer :: sal_emp
   type(hourly_employee),pointer :: hourly_emp
   integer ::istat
   allocate(sal_emp,stat = istat)
   call sal_emp%set_employee('john','jones','111-11-1111')
   call sal_emp%set_salary(3000.0)
   allocate(hourly_emp,stat = istat)
   call hourly_emp%set_employee('jane','jones','222-22-2222')
   call hourly_emp%set_pay_rate(12.50)
   deallocate(sal_emp)
   deallocate(hourly_emp)
end program
following is message for complier error :
employee.f90(33): error #6623: The procedure name of the INTERFACE block conflicts with a name in the encompassing scoping unit.   [CALC_PAYX]
real function calc_payx(salary)
employee.f90: error #8322: A deferred binding is inherited by non-abstract type; It must be overridden.   [CALC_PAY]
employee.f90(191): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [HOURLY_EMPLOYEE_CLASS]
employee.f90(192): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [SALARIED_EMPLOYEE_CLASS]
employee.f90(195): error #6457: This derived type name has not been declared.   [SALARIED_EMPLOYEE]
employee.f90(196): error #6457: This derived type name has not been declared.   [HOURLY_EMPLOYEE]
employee.f90(199): error #6404: This name does not have a type, and must have an explicit type.   [SAL_EMP]
employee.f90(201): error #6460: This is not a field name that is defined in the encompassing structure.   [SET_EMPLOYEE]
employee.f90(202): error #6460: This is not a field name that is defined in the encompassing structure.   [SET_SALARY]
employee.f90(204): error #6404: This name does not have a type, and must have an explicit type.   [HOURLY_EMP]
employee.f90(206): error #6460: This is not a field name that is defined in the encompassing structure.   [SET_PAY_RATE]
compilation aborted for employee.f90 (code 1)
IanH
In the procedure binding statement for the deferred binding in the extended types, you have the binding name and the associated procedure around the wrong way.  Instead of:
you want
procedure,public,nopass:: calc_pay  ! => calc_payx
where calc_payx is the name of the specific procedure - it can be left out if the name of the specific procedure is the same as the name of the binding.
qiu_n_
thank you ,it's ok,but i have other problem for  abstract interface,i want use employee class in my abstract funcation ,how can definite it ? i code is following ,but compile message have error .
  private
  real :: pay = 0
contains
   procedure(calc_payx),public,deferred :: calc_pay
end type employee
abstract interface
real function calc_payx(this,hours,rate)
   implicit none
   import
! error in here
end interface
contains
implicit none
this%ssn = ssn
this%pay = 0
implicit none
implicit none
this%ssn = ssn
implicit none
this%pay = pay
   implicit none
   implicit none
   implicit none
   implicit none
!   implicit none
!   calc_pay_fn = 0
use employee_class
implicit none
   private
   real :: salary = 0
   contains
   procedure,public:: calc_pay
!   procedure,public,nopass:: calc_pay
contains
implicit none
real function calc_pay(this,hours,rate)
implicit none
call this%set_pay(calc_pay)
use employee_class
implicit none
   private
   real :: rate = 0
   contains
   procedure,public :: calc_pay
!   procedure,public,nopass :: calc_pay
contains
implicit none
this%rate = rate
implicit none
  real :: daypay
   implicit none
   integer ::istat
   deallocate(sal_emp)
end program
following is complie error message :
employee.f90(30): error #8041: The IMPORT statement is not positioned correctly within the scoping unit.
   import
employee.f90(31): error #6457: This derived type name has not been declared.   [EMPLOYEE]
employee.f90(28): error #6404: This name does not have a type, and must have an explicit type.   [THIS]
employee.f90(28): error #8262: For a type-bound procedure that has the PASS binding attribute, the first dummy argument must have the same declared type as the type being defined.   [THIS]
employee.f90(45): error #6457: This derived type name has not been declared.   [EMPLOYEE]
employee.f90(59): error #6457: This derived type name has not been declared.   [EMPLOYEE]
employee.f90(70): error #6457: This derived type name has not been declared.   [EMPLOYEE]
employee.f90(79): error #6457: This derived type name has not been declared.   [EMPLOYEE]
employee.f90(88): error #6457: This derived type name has not been declared.   [EMPLOYEE]
employee.f90(94): error #6457: This derived type name has not been declared.   [EMPLOYEE]
Juergen_R_R
Valued Contributor II
The import statement has to be before the implicit none. Then the code compiles.
qiu_n_
thank you. no problem it's ok!
