29435 Discussions
adding more items to the intel fortan help
tropfen
i am using UVF 10.0.013 with VS2005 Std. German.
If i use the fortran help and chose index, i am not able to find items like CB_RESETCONTROL.
Is it possible to add more items like those messages to dialog elements inside the help index? In my view this are essential items.
Thanks in advance
Frank
tropfen
Sorry i was intending to write IVF 10.0.013
Frank
joerg_kuthe
A description of CB_RESETCONTROL (and all the other stuff of theWinAPI) is found in the MSDN online help. Select "Help | Contents" in the menu, and don't try searching the IVF online help (this does not combine both MSDN and VF help as it does with CVF).
Joerg Kuthe
www.qtsoftware.de
tropfen
thanks for the answer. In this case i would like to change my wish to produce a combination of both help systems to one inside IVF.
It would be helpful
Thanks in advance
Frank
Combining the help is not possible at present. We expect to be able to offer that in a future major release.
