allocatable arrays in modules an static memory
Chris_H_3
This was stated in Steve's article on memory for 32 and 64 bit builds:
 In Fortran, COMMON and module variables are always static
Is this true for allocatable arrays in modules as well?
Arjen_Markus
No, it cannot be - allocatable arrays usually have variable sizes (the main reason for making them allocatable) and even if they have the same size throughout the execution of the program, they still have to be allocated before you can use them.
Hence, static and allocatable are not unifiable.
Steven_L_Intel1
I updated the article to make it clear that for POINTER and ALLOCATABLE module variables, it's the "descriptor" that is static.
