ambiguous generic procedure?
clabra
Hi!
I'm testing some modification in my code and I found a problem with the generic interface definitions. In the next sample, the compiler consider ambigous the definition of the procedure, but are different types!
If someone can help me with this, or explain me what is wrong here, please.
[cpp]module types
  implicit none
  private
  type t1_t
    real(8) :: a
  end type
  type t2_t
    integer :: a
  end type
  interface new
    module procedure new_t1, new_t2
  end interface
  public:: t1_t, t2_t, new
contains
  function new_t1()
    type(t1_t), pointer :: new_t1
    allocate(new_t1)
  end function
  function new_t2()
    type(t2_t), pointer :: new_t2
    allocate(new_t2)
  end function
end module types
program test
  use types
  implicit none
  type(t1_t), pointer :: t1
  type(t2_t), pointer :: t2
  t1 => new()
  t2 => new()
end program test[/cpp]
I understand that the compiler should recognize each procedure, or not?
thanks!
Generic functions are distinguished by their arguments: new_t1 and new_t2 have no arguments. Generic resolution isn't done by function result type.
clabra
Ok, thanks Steve.
I will change the function to subroutine.
Maybe in the future can be possible to verify the result type in functions...
If by that you mean the language will allow function result types to participate in generic resolution, that won't happen as there's nothing available to base the selection on. Fortran does not "look at" what is on the left side of an assignment when deciding on the meaning of the right side.
