array bound checking in parameter list of function call
Johannes_Rieke
New Contributor III
Dear all,
in some cases I pass slices of allocated arrays to functions (in modules -> explicit interface) - who does not ;-).
I have encountered a nasty bug in my code, where - although array bound checking is activated - no exception is thrown by the compiler in runtime (16.0.3, 17.0, x64). I can reproduce this in the following example:
module mod_foo
  use ISO_FORTRAN_ENV, only : rk => real64
  implicit none
  private
  public :: rk
  public :: sub_foo
  contains
  subroutine sub_foo(bar_1, bar_2, bar_3)
    implicit none
    real(rk), dimension(:), intent(in   ) :: bar_1
    real(rk), dimension(:), intent(in   ) :: bar_2
    real(rk), dimension(:), intent(  out) :: bar_3
    bar_3(1:10) = bar_1 + bar_2
    return
  end subroutine sub_foo
end module mod_foo
program array_bounds
    use mod_foo
    implicit none
    ! Variables
    real(rk), dimension(:), allocatable :: bar_1
    real(rk), dimension(:), allocatable :: bar_2
    real(rk), dimension(:), allocatable :: bar_3
    ! Body of array_bounds_or_shape
    print *, 'Hello World'
    allocate(bar_1(10))
    allocate(bar_2(10))
    allocate(bar_3(20))
    bar_1 = 1.0_rk
    bar_2 = 2.0_rk
    call sub_foo(bar_1(1:10),bar_2(1:20),bar_3(1:20)) ! this line contains the error: bar_2 has a upper bound of 10!! not captured, why
    write(*,'(*(ES12.4))') bar_3
    bar_2(20) = 0.0_rk ! this is captured
    continue
end program array_bounds
Compiler settings: /nologo /debug:full /Od /warn:interfaces /Qinit:snan /Qinit:arrays /fp:source /module:"x64\Debug\\" /object:"x64\Debug\\" /Fd"x64\Debug\vc140.pdb" /traceback /check:pointer /check:bounds /check:uninit /check:stack /libs:static /threads /dbglibs /c
As commented the call to the function with the obviously wrong bound of bar_2 is not captured, while the bound check two lines below works.
I run the same code under Linux with PSXE 16.0 and GFortran 4.8.3. The Intel version does not throw an exception in the function call line, while GFortran does for the same line:
Fortran runtime error: Index '20' of dimension 1 of array 'bar_2' outside of expected range
It would be nice, if the Intel compilers will catch errors like this. Or is this non-standard Fortran?
Best regards, Johannes
jimdempseyatthecove
What happens when you change sub_foo, bar_2 to have intent(inout), then add at line 18, bar_2(15) = 1.0?
IOW actually use a location that is out of bounds.
Jim Dempsey
Steven_L_Intel1
The compiler is simply not doing bounds checking for array slices as actual arguments. I have submitted a request that it do so - DPD200415122.
