array bounds exceeded
ecc26
I'm getting error 161 while running this code; array bounds exceeded. How can I find out what array is in question. The error names the line where the code stopped but it doesn't seem to be anything wrong in there.
thank you,
The easiest way is to run the program under the debugger - when it stops, you can examine variables used as array indexes.
Steve
