29390 Discussions
assembler compatibility with ifort -S
TimP
Is there a way to make ml64 or some assembler accept ifort .asm files?  ml64 rejects the code labels beginning with '.'.
I'm looking for a way to test the "ALIGN     16" code alignment directives which come and go with various ifort releases, particularly when AVX2 is set.
A related confusing issue comes up when setting AVX2 reduces the unrolling.  Opt-report (and Advisor) don't report unrolling when it is not done consistent with Qunroll: or setting.
When I run VTune or Advisor on ifort generated .exe, sometimes where ifort decides to align, the alignments come out different by up to 3 bytes.  This doesn't appear to hurt, even when the loop is placed 3 bytes ahead of an aligned address.
In a few cases where gfortran decides to align code, but ifort doesn't, there may be a 30% speedup with alignment on my Haswell.  I'm guessing it makes Loop Stream Detection more effective.
My recollection is that on Windows, the .asm files you get from ifort are not usable with ml - that they are for informational purposes only.
