assignment efficiency
lklawrie
Is it more efficient to assign via a Do loop:
do i=1,n
x(i)=someotherarray(i,1)
enddo
or
x(1:n)=someotherarray(1:n,1)
or does it matter?
Linda
TimP
For a rank 1 assignment, it's not likely to make a difference.
abhimodak
Hi Linda
If you are using Win64 and have large arrays you may want to take a quick look at : http://software.intel.com/en-us/forums/showthread.php?t=61077
The last post by Mr. Green indicates that Intel may need do a little bit of further analysis, but based on the response received in Premier Support, I think Intel has pulled the plug on it. (The outer "dead" loop pointed out by Mr. Green is not optimized-out in even in the latest release 11.1.060. But as far as I know this happens only on Win64.)
Also I recall that Steve Lionel had mentioned somewhere to use the whole array syntax instead of specifying the complete partition, if it is possible i.e. avoid A(1:N) = B(1:N) and use A = B if the array size is N. (I interprete this as compiler may think it has to do something extra when the partition is mentioned.)
Abhi
abhimodak
Hi Tim
Does this mean for rank n with n>1 would have a bigger impact? Can you please illustrate this point with an example? It may be super-elementary but I think it is worth to "put it on the cap"; your advice deeply appreciated.
Sincerely
Abhi
Is n the upper bound of array x? If so, then remove the (1:n).
