29390 Discussions
associated unexpectedly returns false on pointer associated with derived type
jhaiducek
I have a program that associates a pointer to an instance of a derived type, then checks whether the pointer is associated with the intended object. When I compile the program with ifort (19.0.4.243), the associated() function returns false.
The program is as follows:
module mod_pointer_association
  type mytype
  end type mytype
contains
  subroutine test_association(obj)
    class(mytype), target, intent(in)::obj
    class(mytype), pointer::ptr
    ptr=>obj
    if (.not. associated(ptr)) then
       print *, "ptr not associated"
       error stop
    end if
    if (.not. associated(ptr, obj)) then
       print *, "ptr not associated with obj"
       error stop
    end if
  end subroutine test_association
end module mod_pointer_association
program test_pointer_association
  use mod_pointer_association
  type(mytype), target::myobj
  call test_association(myobj)
end program test_pointer_association
The program produces the following output when compiled with ifort 19.0.4.243:
$ ./test_pointer_association
Which suggests that either the => or the associated intrinsic function did not perform the function I expect it to, because the associated function returned False when called with the pointed-to variable as the target, immediately after using => to associate the pointer.
The same program produces no output (as expected) when compiled with gfortran 9.2.0.
TobiasK
Hi @jhaiducek
can you please try to add something to your derived type?
If I add an integer for example, your program works as you expect. Is there a real use case where you want to have an empty derived type or is this just a toy example?
Best
Tobias
TobiasK
Hi @jhaiducek
Has your issue been resolved? If I don't hear from you within 5 business days, I will assume your support request is resolved and you no longer need assistance
TobiasK
Hi @jhaiducek
please open a new thread if you need further assistance.
