automatic scalar character allocation vs. automatic integer array allocation
may_ka
Hi there,
the code below shows a different behaviour for allocatable scalar characters vs allocatable integer arrays:
Program Test
  Implicit None
  Character(:), allocatable :: csa,csb
  integer, allocatable :: iva(:), ivb(:)
  write(*,*) "character scalar"
  write(*,*) allocated(csa), allocated(csb)
  csb=csa
  write(*,*) "integer vector"
  write(*,*) allocated(iva), allocated(ivb)
  ivb=iva
  write(*,*) "character scalar allocated"
  csa="a";deallocate(csb)
  csb=csa
  write(*,*) "integer vector allocated"
  allocate(iva(5))
  ivb=iva
End Program Test
The output is:
character scalar
 F F
 F T
 integer vector
 F F
 F F
 T F
 T T
 T F
 T T
The result was obtain with ifort 17.0.5.
Any clarification whether this is meant to be or not is appreciated.
Cheers
Steve_Lionel
In the first csb=csa, where both csb and csa are initially deallocated, it's incorrect that csb becomes allocated. Since csa is deallocated, csb should remain deallocated. Please report this through the Intel Service Center.
IanH
The compiler can do whatever it wants, as the references to unallocated objects in the expressions on the right hand side of the assignment statements are nonconforming.
Steve_Lionel
Ian is correct - I was thinking of a different situation.
FortranFan
ianh wrote:
The compiler can do whatever it wants,  ..
Indeed but glad that Intel Fortran compiler provides the -check run-time error checking facility:
https://software.intel.com/en-us/fortran-compiler-18.0-developer-guide-and-reference-locating-run-time-errors
https://software.intel.com/en-us/fortran-compiler-18.0-developer-guide-and-reference-check
that will lead to a run-time error for the instruction corresponding to statement on line 7 in the original post.
