bash intel linux setup
diedro
Dear intel linux user,
The fortran ifort does not work on my bash.
As I usually do in my ubuntu, I have opened the bash.bashrc file and I have put the following line:
source /opt/intel/bin/compilervars.sh intel64
source /opt/intel/mkl/bin/mklvars.sh intel64 mod lp64
export PATH
The problem is that the ifort does not work. I have already tried to restart ubuntu.
The is the message:
ifort: command not found
What do you think the problem could be?
thanks a lot
TimP
Could you try the settings individually on command line to see where it goes wrong? If the first source command works, possibly a later one is breaking it. If not, possibly you don't have a working symlink in /opt/intel/bin. I usually run find in /opt/intel to see which compilervars.sh I will require.
diedro
Dear Tim, Dear intel linux user,
I find the error, it was an ubuntu error. Ubuntu 14.04 needs to shut down to have the new bash configuration, the only restart is not enough.
Thanks a lot
diedro
dear intel user,
now I have this error in "Checking the prerequisites"
/tmp/install.SScuJX/li_gen_bash.SMDhGI: 2358: local: intel-vtune-amplifier-xe-doc-243421-13.1-0.noarch: bad variable name
/tmp/install.SScuJX/li_gen_bash.vMpReZ: 2358: local: intel-inspector-xe-cli-242865-13.1-0.x86_64: bad variable name
/tmp/install.SScuJX/li_gen_bash.B7jElM: 2358: local: intel-advisor-xe-cli-242805-13.1-0.x86_64: bad variable name
What can I do to fix it?
Diego
