beginner..please help
nmir
hi all,
i this is the first time i am using this forum as well as CVF,i would appreciate if someone could tell where is the best place to start if someone is a beginner, i mean who does not know anything about programming.
secondly, i'm mostly interested in creating subroutines and finally i am also required to create source files or source codes . seriously i dont have a clue of what i'm talking about.
the above mentioned are basically used in the adams 12.0 software which uses a fortran based solver (also C++ based, but i'm not interested in it at this moment).
from what i have read in the samples it seems a bit too much for me, is there anywhere i can get simple and easy to understand tutorials.
please point me in the right direction.
nihal.
garyscott
Recommend thatyou might also get some good advice if you post your message to:
news:comp.lang.fortran
ArturGuzik
Valued Contributor I
Nihal,
a good start may be FORTRAN 90 Programming by Ellis, Philips, Lahey. I've been told that Fortran 90/95 for Scientists and Engineers is also very good.
A.
