Hi ,
I wonder what is exactly the good behavior for a function y=f(y) which return a greater array:
1) When y is an allocatable array ,
2) When y is a type containing an allocatable array.
From my experiments,
for an allocatable array there is no error saying the return array is not the same size (even whit -C ) and the result is just copied up to the declared size of y. If i deallocate y in f then i got a segfault, which i can understand since it assume norealloc-lhs. ( this works with gfortran 4.7 so i believe they have enabled realloc-lhs by default)
For a type there is no error and the returned type has the good size and array, which i believe realloc-lhs is enabled for type. If i deallocate the array in the type in f then it gets reallocated at the good size. ( GCC give me a double free corruption here).
So finally, if assume no-realloc by default why not for type ? and should the compiler throw an error for the size mismatch instead of silently fill the array ?
[fortran]program test
implicit none
! real,pointer :: matrix(:,:),diagonal(:),base_array(:)
! allocate(matrix(5,5))
! base_array => matrix
type po
double precision,dimension(:),allocatable :: p
end type
integer :: i
double precision,dimension(:),allocatable :: p1p
type(po) :: p1
allocate(p1%p(1))
do i=1,10
p1%p=1d0
p1=toto(p1)
end do
print *,'p',p1%p
contains
function toto(dd) result(y)
!double precision,dimension(:),allocatable :: ddp,yp
type(po) ::dd,y
allocate(y%p(10))
!deallocate(dd%p)
y%p=3d0
! print *,'yp',yp
end function toto
end program test[/fortran]
链接已复制
1 回复
