the draft Fortran 2015 standard reads: An actual argument of any rank may correspond to an assumed-rank dummy argument. The rank and shape of the dummy argument are the rank and shape of the corresponding actual argument. If the rank is nonzero, the lower and upper bounds of the dummy argument are those that would be given by the intrinsic functions LBOUND and UBOUND respectively if applied to the actual argument, except that when the actual argument is assumed-size, the upper bound of the last dimension of the dummy argument is 2 less than the lower bound of that dimension. (section 12.5.2.4 on ordinary dummy variables, paragraph 15) Here is a small test program: program assumedrank implicit none real,dimension(:,:,:),allocatable :: bb real,dimension(3:9,10:15,16:32) :: c allocate(bb(3:9,10:15,16:32)) print*, 'Actual argument, allocatable, lbound=',lbound(bb) call p(bb) print*, 'Actual argument, lbound=',lbound(c) call p(c) contains subroutine p(a) real,dimension(..) :: a print*,'Dummy argument, lbound=',lbound(a) end subroutine p end The Intel 16.0.0 compiler returns the correct lower bounds for an allocatable array as actual argument (note that there is no allocatable keyword for the dummy argument), but it returns 1 1 1 for the fixed-shape array. The standard suggests that it should also have the lower bounds of the actual argument in the latter case. Cheers,
John
(PS: gfortran 5.2.0 returns 1 1 1 as the lower bounds, both for the allocatable and the fixed-shape array.)
Thank you for the post. I submitted this to Development.
(Internal tracking id: DPD200377056)
(Resolution Update on 02/22/2016): This defect is fixed in the Intel® Parallel Studio XE 2016 Update 2 Release (PSXE 2016.2.062/ CnL 2016.2.181 - Linux)
I see that this problem was resolved in Intel Fortran 16.0.2. Many thanks!
Thank you for your post. Yes, that is correct. You beat me to the confirmation/verification. As you noted, this is fixed in the recently announced PSXE 2016 Update 2 release (PSXE 2016.2.062/ CnL 2016.2.181 - Linux)
