29487 Discussions
bug in 11.1 with PROCEDURE in TYPE declarations
konstantinos
[cpp]!=================================================================================
!  TestFile.f90
!   By Konstantinos, last modified 18/12/09
!           S U B R O U T I N E   M O D U L E S					            |
MODULE SmallObjectDerDataTypes
IMPLICIT NONE
TYPE SmallObject
	REAL(KIND=8),DIMENSION(:),POINTER:: RealParameter
END TYPE SmallObject
END MODULE SmallObjectDerDataTypes
MODULE ErrorObjectDerDataTypes
IMPLICIT NONE
TYPE ErrorObject
	INTEGER(KIND=4):: IntegerParameter
END TYPE ErrorObject
END MODULE ErrorObjectDerDataTypes
MODULE BigObjectDerDataTypes
USE SmallObjectDerDataTypes
IMPLICIT NONE
TYPE BigObjectProcedures
	PROCEDURE(BigObjectParentMethodAbstract),POINTER,NOPASS:: ParentMethod
END TYPE BigObjectProcedures
TYPE,EXTENDS(SmallObject):: BigObject
	TYPE(BigObjectProcedures):: Proc
END TYPE BigObject
ABSTRACT INTERFACE
	SUBROUTINE BigObjectParentMethodAbstract(DV, ErrDV)
		USE ErrorObjectDerDataTypes
		IMPLICIT NONE
		CLASS(SmallObject),INTENT(INOUT):: DV
		TYPE(ErrorObject),INTENT(INOUT):: ErrDV
	END SUBROUTINE BigObjectParentMethodAbstract
END INTERFACE
END MODULE BigObjectDerDataTypes
MODULE FamilyObjectDerDataTypes
	USE BigObjectDerDataTypes
END MODULE FamilyObjectDerDataTypes
!           S U B R O U T I N E   C O D E S						            |
MODULE InnerSubroutineInterface
INTERFACE
	SUBROUTINE InnerSubroutine(DV, ErrDV)
			USE FamilyObjectDerDataTypes
			IMPLICIT NONE
			TYPE(BigObject),INTENT(INOUT):: DV
	END SUBROUTINE InnerSubroutine
END INTERFACE
END MODULE InnerSubroutineInterface
		IMPLICIT NONE
MODULE MainSubroutineInterface
INTERFACE
	SUBROUTINE MainSubroutine(DV, ErrDV)
			IMPLICIT NONE
	END SUBROUTINE MainSubroutine
END INTERFACE
END MODULE MainSubroutineInterface
		USE InnerSubroutineInterface
		IMPLICIT NONE
		CALL InnerSubroutine(DV = DV, ErrDV = ErrDV)
The piece of FORTRAN code above will fail to compile with Intel Visual Fortran 11.1.051 [IA-32]
The error message given is:
C:Documents and Settingsc101731My DocumentsVisual Studio 2005ProjectsEVA Greater ProjectEVA Source CodePerformance ModuleTestFile.f90(169): internal error: Please visit 'http://www.intel.com/software/products/support' for assistance.
[ Aborting due to internal error. ]
compilation aborted for C:Documents and Settingsc101731My DocumentsVisual Studio 2005ProjectsEVA Greater ProjectEVA Source CodePerformance ModuleTestFile.f90 (code 1)
Removing the following line will fix the problem, but that is the important bit I require from the code:
PROCEDURE
There may be a clash because of the use of the "USE FamilyObjectDerDataTypes"
in both within "SUBROUTINE InnerSubroutine" and
within "SUBROUTINE MainSubroutineInterface"
Is this a bug with the compiler?Is the particular PROCEDURE feauture not supported yet?
I need to use this kind of structure i.e. MainSubroutine, and Inner Subroutine so are
there any potential work-arounds with this, to both keep the current structure and also be able to have the PROCEDURE
component in the derived data type declaration to bind subroutines to the object.
Kind Regards
Konstantinos
[/cpp]
Lorri_M_Intel
I took your example program above and compiled it with the 11.1 Update 4 compiler (which I believe is now available?) and it compiled successfully.
We fixed some type-bound procedure problems in that release, and it looks like yours was one of them.
Good news for a Friday!
- Lorri
konstantinos
- Lorri
I donwloaded the evaluation version of the Intel fortran compiler
for windows (if that makes a difference) on the 17th Dec 2009 i.e. justyesterday.
Theversion number was 11.1.0.51
I just checked the website for an updateversion -
Current status is11.1 update 4 with exact version number being11.1.054.
Wasthat the version you used for compiling the code?
I'll try installing an evaluation copy of .054to see if that makes the difference.
I compile with the following options:
/nologo /debug:full /Od /gen-interfaces /warn:interfaces
/module:"Debug" /object:"Debug" /traceback /check:bounds /libs:static /threads /dbglibs /c
I'll post a reply if I get this working with .054.
11.1.054 is Update 4. 11.1.051 is Update 3.
konstantinos
I tested it with 11.1.054 (Update) and it worked fine.
Thanks for the feedback
Konstantinos
