29634 Discussions
bug report: Coarray character variable
michalkuraz
hello,
I receiveSIGSEGV segmentation fault with simple operation on coarray variable of character type.
here is the code
program bugrep
implicit none
character(len=1) :: test
  • if (this_image() == 1) then
    test[1] = "a"
    !on this print the first image terminates
    print *, test[1]
    end if
    sync all
    if (this_image() /= 1) then
    print *, "ready to print"
    !on this print the other images terminate as well
    print *, test[1]
    end if
    end program bugrep
    ifort version:Version 12.0.0
    operating system: debian squeeze and ubuntu maverick (the same behaviour occured)
    compilation command:ifort -coarray bugrep.f90
    Ron_Green
    Character Coarrays are not supported at this time.
    ron
