29649 Discussions
byte alignment with Fortran allocate
scott_palmtag
We are investigating some instabilities with the MLK BLAS library and we found some documentation that
said arrays should be aligned on 16-bye boundaries.
It also said that arrays allocated with MALLOC are aligned on 8-byte boundaries.
Are single precision arrays allocated with Fortran ALLOCATE statements aligned on 8-byte or 16-byte boundaries?
Do we need to specify a special compiler flag to get 16-bye alignment?
You can use !DEC$ ATTRIBUTES ALIGN to specify that an allocatable variable should have a particular alignment.
scott_palmtag
I guess my question is do I have to use this, or are they already 16-byte aligned?
We have over 1000 arrays that are allocated.
Jugoslav_Dujic
Valued Contributor II
Yes, I'm afraid you have to. Some find/replace with regular expression and/or keyboard macros could automate the task :-).
We had an extensive discussion on the feature recently here:
http://software.intel.com/en-us/forums/showthread.php?t=59480
