call to system - CPU time
ndsr
HI,
I would like to know the CPU time and I should call it in my script
specify the call to the system subroutine to learn CPU time
SUBROUTINE TIMEL(TRES)
* Returns CPU time. *
REAL*8 TRES,TRES0
INTRINSIC SYSTEM_CLOCK
C EXTERNAL CPSEC
SAVE IF,TRES0,IRES0
DATA IF/0/
* THIS IS THE <> CALL TO LEARN CPU TIME
C TRES=MCLOCK()/100.d0
C RETURN
C CALL DCLOCK@(TRES)
C IF(IF.EQ.0)TRES0=TRES
C IF=1
C TRES=TRES-TRES0
C RETURN
* THIS IS INTRINSIC PROCEDURE IN FORTRAN<90>
C IF(IF.EQ.0)CALL SYSTEM_CLOCK(IRES0,IRESR,IRESM)
C IF=1
C CALL SYSTEM_CLOCK(IRES,IRESR,IRESM)
C TRES=DBLE(IRES-IRES0)/DBLE(IRESR)
* THIS IS THE MICROSOFT FORTRAN POWER STATION CALL
C IF(IF.EQ.0)TRES0=CPSEC()
C TRES=CPSEC()
C TRES=TRES-TRES0
C IF=1
TRES=0.D0
END
this is the script and where should I specify the call
Pl advice me
mecej4
[bash]      SUBROUTINE TIMEL(TRES)
* Returns CPU time.  Fortran 9X version                          *
      REAL*8 TRES,TRES0
      SAVE IF,TRES0,IRES0
      DATA IF/0/
     IF=1
      END
[/bash]
rreis
The piece of program already tells you how to do it, after each * line there is the code for doing what you want, you just have to uncomment it (remove the initial "C" of each line).
In what architecture will you running this program?
ndsr
Dear Reis,
I would like to run this on a 32 bit architecture and my processor speed is 2.93 Ghz. So how should I specify
TimP
You might take into account that system_clock() works much better with 64-bit integers. One more reason for explicit declarations.
ndsr
HOw can I able to specify 64 bit when my system architecture is 32-bit
TimP
You choose the 35 year old non-standard way of specifying 64-bit real, if you choose to be further non-standard you can so the same with integer (integer*8), or you can adopt the way which came in together with system_clock:
integer(selected_int_kind(12)) :: ires0,iresr,iresm,ires
Intel Fortran for IA-32 supports 64-bit integers.
ndsr
Thank you TIM
but can you put that in the code which I've geiven so that would give me clearly
mecej4
      REAL*8 TRES,TRES0
      SAVE IF,TRES0,IRES0
      DATA IF/0/
     IF=1
      END
[/bash]
Please note that SYSTEM_CLOCK returns "wall clock" elapsed time, not CPU time. The CPU_TIME intrinsic returns that.
ndsr
It has been so long and after my PC crashed out. I reinstated my PC and Now I exactly got what I can do I'll keep posted on the improvement
