I basically want to call the following struct in .c from fortran as follows
struct AZNames{
int Number;
char *Name;
char *Unit;
int Typ;
static struct AZName AZLNames[] = {
{1, "Interaction G(%d)" , "Sa", 1}
{2, "Object H(%d)" , "Da", 3}
{3, "Action G(%d)" , "Fa", 2}
... what I really want to achieve is a state in fortran in which if I give in a randomlly selected number i.e 1, 2 or 3 ..., I recieve the corresponding Name, unit and Typ as stated in the struct.
... I have tried out a couple of methods calling this struct from fortran but still pretty much not close to my aim.
:-l
struct AZNames{
int Number;
char *Name;
char *Unit;
int Typ;
:-l
Possible Fortran equivalents are:
Also, pay attention that strings coming from C must be (char(0)) terminated, and whatever comes after that is undefined.
HTH
Jugoslav
TYPE AZnames INTEGER:: Number CHARACTER(xxx), POINTER:: Name => NULL() CHARACTER(xxx), POINTER:: Unit => NULL() INTEGER:: Typ END TYPEor
TYPE AZnames INTEGER:: Number INTEGER(INT_PTR_KIND()):: Name INTEGER(INT_PTR_KIND()):: Unit INTEGER:: Typ END TYPEUnderlying CVF implementation of CHARACTER(), POINTER happens to be the same as char*. You should put some sufficiently big value instead of xxx to be able to hold the longest value. It's not clear from your post who fills in the structure (C or Fortran) -- if it's Fortran, you must take care to ALLOCATE Name and Unit before use (but you must not if it's C). The second translation would require use of LOC() routine. (I'd recommend the first unless you need portability).
HTH
Jugoslav
You might need a
All the best,
Eddie
SEQUENCEstatement after the
TYPEstatement. This ensures that the compiler doesn't optimise the order of the entries in the structure, and make it different from the C code.
All the best,
Eddie
I understand your replies.
However I transformed the tip as such that if I can basically extract the data from .c and then pass it to a fortran subroutine which can thus be called up from any other fortran programm.
I guess that was going to get me to my aim,which is to use the data in .c by calling it from Fortran, which I guess you probably missunderstood because of my inexplicit explanation.
Nevertheless, I tried the following below,... it compiled the fortran subroutine sure without error but in trying to build an exe it gave out 2 Erroes
unresolved external _MAIN
unresolved external _EXTRACT
I have tried to correct this error with little success.
main()
f1 (AZLNames);
return;
void extract (struct AZNames* a, int* ix, int* Number, char* Name, char* Unit, i
nt* Typ)
*Number = a[*ix-1].Number;
strcpy(Name, a[*ix-1].Name);
strcpy(Unit, a[*ix-1].Unit);
*Typ = a[*ix-1].Typ;
C ------ Fortan subroutine ------
subroutine f1(a)
character*80 a
character*80 name, unit
integer*4 number, typ, ix
ix = 2
call extract(a, ix, number, name, unit, typ)
print *, number, name, unit, typ
return
end
...can possibly someone help out to get me out of this error or basically something new to get me to the goal of being able to use the data in the struct form from .c calling it from fortran 90 such that if I give in the Number I should recieve thecorresponding Name, Unit and Type.
Pls: See earlier post from me to this topic
main()
f1 (AZLNames);
return;
nt* Typ)
subroutine f1(a)
character*80 a
ix = 2
return
end
Did you read the Mixed-Language Programming chapter in Programmer's Guide? The error comes from the fact that Visual C++ mangles names as-is, while in Intel Fortran the default is uppercase -- linker searches for _EXTRACT, but finds only _extract.
You should specify an INTERFACE block for extract in Fortran code to tell the compiler what extract really is (and CHARACTER data type is not the best choice for representation -- there are hidden length arguments around -- use something else):
subroutine f1(a) integer:: a character*80 name, unit integer*4 number, typ, ix interface subroutine extract(a, ix, number, name, unit, typ) !dec$attributes C, REFERENCE:: extract integer:: a, ix, number, typ !dec$attributes REFERENCE:: name !dec$attributes REFERENCE:: unit character(*):: name character(*):: unit end subroutine extract end interface ix = 2 call extract(a, ix, number, name, unit, typ) !It's probably a good idea to strip trailing char(0): name = name(1:index(name,char(0))) unit = unit(1:index(unit,char(0))) print *, number, name, unit, typ return endJugoslav
