can't find windows class
rjar
Débutant
1 469 Visites
I try to create a dialog box using DialogBoxParam function but I get the following error:
ret = DialogBoxParam(ghInstance,IDD_DIALOG_list,hWnd,LOC(listdlgProc), 0)
ERROR_CANNOT_FIND_WND_CLASS Cannot find window class. 1407
Why does this error occur?
archana
0 Compliments
4 Réponses
nijhuis
Débutant
1 469 Visites
It is most likely that your construction of the IDD_DIALOG_list is incorrect. This argument contains the DLGTEMPLATE-structure immediately followed by a menu array, a class array and a title array. This main template is followed bij "n" DLGITEMTEMPLATEs, in which "n" is defined in the DLGTEMPLATE.
Each DLGITEMTEMPLATE is followed by 3 arrays containing class, title and creation date elements.
Be sure each array starts at a WORD (=integer*2) boundary.
I will advise you to carefully follow the rules in the documentation of the templates, because is it a hell of a job to get it working.
Guus
0 Compliments
rjar
Débutant
1 469 Visites
This is the About dialogbox resource from the .rc file in my project:
// Dialog
ABOUTDLG DIALOG FIXED PURE 22, 17, 167, 64
STYLE DS_MODALFRAME | WS_VISIBLE | WS_CAPTION | WS_SYSMENU
CAPTION "About checkbox_listview"
BEGIN
DEFPUSHBUTTON "OK",IDOK,132,2,32,14
ICON "checkbox_listview",-1,2,3,1,1
LTEXT "CompanyName",IDC_VER1,30,2,100,8
LTEXT "FileDescription",IDC_VER2,30,10,82,8
LTEXT "ProductVersion",IDC_VER3,114,10,16,8
LTEXT "LegalCopyright ",IDC_VER4,30,18,137,8
LTEXT "LegalTrademarks",IDC_VER5,30,34,136,27
CONTROL "",501,"Static",SS_BLACKRECT,28,31,138,1
END
#endif // Neutral resources
and this is the IDD_DIALOG_LIST resource from the same .rc file:
// Dialog
IDD_DIALOG_list DIALOG FIXED PURE 0, 0, 212, 127
CAPTION "Dialog"
FONT 8, "MS Sans Serif"
BEGIN
DEFPUSHBUTTON "OK",IDOK,155,7,50,14
PUSHBUTTON "Cancel",IDCANCEL,155,24,50,14
CONTROL "List1",IDC_LIST1,"SysListView32",LVS_REPORT | WS_BORDER |
WS_TABSTOP,7,7,147,113
END
lpszName = "AboutDlg"C
ret = DialogBoxParam(ghInstance,LOC(lpszName),hWnd,&
LOC(AboutDlgProc), 0)
This call succeeds.
______________________________________________________
ret = DialogBoxParam(ghInstance,IDD_DIALOG_LIST1,hWnd,&
This call fails.
How is the argument for the second different from the first. What must the dialogbox template argument be.Thanks
-archana
0 Compliments
nijhuis
Débutant
1 469 Visites
Hi Archana,
Sorry I overwhelmed you with my reply on the dialog template, but I was focused on the way I fill in the template and that is completely via a Fortran routine. I get the information for the build of the dialog during runtime and then the building of a template indeed is a hell of a job.
I don't see the problem in the way you apply it. The only thing I see is you use the name IDD_DIALOG_LIST1, but I assume this is a typo.
Guus
0 Compliments
rjar
Débutant
1 469 Visites
This project is a new one. This DialogBox call fails irrespective of which resource_id I use,IDD_DIALOG_LIST, IDD_DIALOG1. And get last error returns 1407:Can't find windows class.
I have other projects where I have succesfully used the same command with a similar call to DialogBox as this one. Is it some library I have to include?. I think the problem could be with the resource definition because I can use AboutDlgProc as the default callback routine.
-archana
0 Compliments
Répondre
