29413 Discussions
cannot open file 'ifconsol.lib'
barakobama
I got a link error:
LINK : fatal error LNK1104: cannot open file 'ifconsol.lib'
The file is there but the compiler not finding it.
I am making a 32bit version on Xeon with Intel Fortran 9.1 [IA32].
My lib environment which I get from "Options" under "Tool" menu is:
$(IFORTInstallDir)Lib
$(VCInstallDir)lib
$(VCInstallDir)atlmfclib
$(VCInstallDir)atlmfclibi386
$(VCInstallDir)PlatformSDKlib
$(FrameworkSDKDir)lib
$(VSInstallDir)
$(VSInstallDir)lib
C:Program Files (x86)Microsoft Visual Studio 8VCATLMFCLIB
C:Program Files (x86)Microsoft Visual Studio 8VCLIB
C:Program Files (x86)Microsoft Visual Studio 8VCPlatformSDKlib
C:Program Files (x86)Microsoft Visual Studio 8SDKv2.0lib
%IFORT_COMPILER91%IA32Lib
%IFORT_COMPILER91%EM64TLib
Could you please let me know what's wrong?
-BO
Steven_L_Intel1
Is this an all-Fortran project or is there C/C++ code? Can you post the buildlog.htm contents?
barakobama
It's a mixed soln with C and Fortran.
Here is the log start and end with some of the middlelog deleted.
1>------ Rebuild All started: Project: tg230_lib, Configuration: Debug Win32 ------
1>Deleting intermediate files and output files for project 'tg230_lib', configuration 'Debug|Win32'.
1>Compiling with Intel Fortran 9.1 C:Program Files (x86)IntelCompilerFortran9.1IA32...
1>tascflow ascflw9.f
1>projectpspher.f
1>partsstarseq.f
1>partsextrude.f
1>parseadmicr.f
1>outputotopaz3d.f
1>output eutral.f
1>outputennike3d.f
1>options zopts.f
1>optionsdnopts.f
1>mergelocate.f
1>irisguispecfnc.f
1>C: gsrc.230irisguispecfnc.f(1436) : Warning: The data type of the actual argument does not match the definition. [1]
1>irisguimenustrg.f
1>C: gsrc.230irisguimenustrg.f(94) : Warning: The data type of the actual argument does not match the definition. [1]
1>irisguiguips.f
1>C: gsrc.230irisguiguips.f(181) : Warning: The data type of the actual argument does not match the definition. [1]
1>irisguiGlonlymovesrc.f
1>irisguidwbttn.f
1>.includedeflgop.h(31) : Info: This statement function has not been used. [JSHIFTR]
1>.includedeflgop.h(41) : Info: This statement function has not been used. [JSHIFTL]
1>.includedeflgop.h(21) : Info: This statement function has not been used. [JOR]
1>C: gsrc.230irisguidwbttn.f(638) : Warning: The data type of the actual argument does not match the definition. [1]
1>interpolxcurves.f
1>interpolmesh.f
1>inputindyna3d.f
DELETED: because it's too long.
2>c: gsrc.230secure3setmcc.c(323) : warning C4305: 'function' : truncation from 'double' to 'float'
2>c: gsrc.230secure3setmcc.c(757) : warning C4996: 'strncpy': This function or variable may be unsafe. Consider using strncpy_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
2> c:program files (x86)microsoft visual studio 8vcincludestring.h(157) : see declaration of 'strncpy'
2>c: gsrc.230secure3setmcc.c(758) : warning C4996: 'strncpy': This function or variable may be unsafe. Consider using strncpy_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
2>c: gsrc.230secure3setmcc.c(771) : warning C4996: 'strcpy': This function or variable may be unsafe. Consider using strcpy_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
2> c:program files (x86)microsoft visual studio 8vcincludestring.h(74) : see declaration of 'strcpy'
2>c: gsrc.230secure3setmcc.c(781) : warning C4101: 'l' : unreferenced local variable
2>c: gsrc.230secure3setmcc.c(780) : warning C4101: 'j' : unreferenced local variable
2>Generating Code...
2>Compiling resources...
2>Compiling manifest to resources...
2>Linking...
2>LINK : fatal error LNK1104: cannot open file 'ifconsol.lib'
2>Build log was saved at "file://c: gsrc.230DEBUGBuildLog.htm"
2>tg230 - 1 error(s), 923 warning(s)
========== Rebuild All: 1 succeeded, 1 failed, 0 skipped =========
Steven_L_Intel1
I thought so.
In Visual Studio, go to Tools > Options > Projects > VC++ Directories. For "Library Files", add the full path to the Intel Fortran "Lib" folder.
barakobama
It solved the problem and I successfully made the 32 bit version
on Xeon.
Now, I am trying to make a 64bit version and got the link error:
2>tg230_lib.lib(dialog1.obj) : error LNK2001: unresolved external symbol _for_write_seq_fmt.
I checked the forum in the past and set:
Disable Default Library Search Rules: No
for my Debug Configuration.
FYI: I set the environment as below for the 64 bit version:
Fortran side:
Set Target Platform: x64 which also set Slected Compiler
as Intel Fortran 9.1 [IA32_EM64T] automatically.
Library directory is set as
C:Program Files (x86)IntelCompilerFortran9.1em64tLib
VC++ side:
VC Projects and Solutions:
VC++ directories:
Platforms: x64
It's done in "Options" under "Tools".
Steven_L_Intel1
You're using VS2005, yes? You need to create an "x64" configuration. This is explained in the "Building Applications" section of the on-disk documentation. You're compiling using the 32-bit compiler.
barakobama
I followed the step to setup 64-bit version as you suggested.
Now, I got the error:
1>------ Build started: Project: tg230, Configuration: Debug x64 ------
1>Linking...
1>LINK : fatal error LNK1104: cannot open file 'ifconsol.lib'
1>Build log was saved at "file://c: gsrc.230x64DebugBuildLog.htm"
1>tg230 - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 1 up-to-date, 0 skipped ==========
I put the following path into the VC++ directories:
which is for 64bit.
Related to this, there is a strange behavior in the Options Dialog.
In VC++ Directories of "Porjects and Solutions" node under "Tools",
I can not set the Platform x64 from Win32. It stays Win32 when I get back and open the Option dialog even though I set it to x64 and clicked OK.
-BO
Steven_L_Intel1
Which edition of VS2005 do you have? If it is anything but the Standard Edition, you need to do a "Change" on it in Add/Remove programs to add the Visual C++ > x64 Compiler and Tools option, as it is not installed by default.
Once you have done so, you'll find that the directory lists are different for "Win32" and "x64". Make sure you select the right platform when updating the lists.
barakobama
I'm using VS2005 Standard Edition.
So, I have seperate directories for 32 and 64.
Thanks to your help, I do not have the link error for "ifconsol.lib" any more. When I switchtheplatform to x64,I see the directory lists have been changed. However, I can make it stay as x64. When I revisit the Option for VC++ Directories,platform is still Win32.
Any idea?
-BO
barakobama
I found a way to set x64 for VC++ directories.
I set up the environment using command prompt and then fire up
vs2005 from the prompt window.
Start menu->Visual Studio Tools->x64 Win64 Command prompt
"C:Program Files (x86)Microsoft Visual Studio 8Common7IDEdevenv.exe" /useenv
If I use this method, the list will not change whether it's Win32 or x64.
It shows the ones only for x64.
But I would like to understand why I can not set x64 if I do not use the 64 env prompt.
******Another question:
Some of my routinesare using 3rd party library which does not have 64bit version and got errors because of it. Is there a way of specifying the library(i.e.use this 32bit library)to use only for a specific routine while others remain 64bit?
Steven_L_Intel1
You do not need to use the command prompt. When you want to build a 64-bit application, you must add an "x64" target configuration to your project. The instructions for doing this are in the documentation.
You cannot mix 32-bit and 64-bit code in an application.
barakobama
Thanks to your help, I sucessfully built the 32 and 64 bit versions.
Now I am trying to build release version starting from 32bit.
I am gettting some unresolved external link errors, i.e. "strlen()", "sprintf()", "printf()" etc. though
it has the proper and in the files.But the same code is working for debugging version.
Could you tell me if there are any major differences in setttingsbetween debugging and release version. I am using mixed Fortran and C?
-BO
levicki
Valued Contributor I
It probably means that your C libraries somehow get ignored by the linker. Check your build log, project settings, especially if /Zl option is perhaps active. To me it seems like your installation of development toolchain is messed up. I would uninstall everything if I were you and start from scratch.
Steven_L_Intel1
In addition to what Igor mentions, I'd guess that in your attempt to solve the problem earlier you made some incorrect changes to your project. You do need to make sure that the C and Fortran projects use the SAME libraries setting, such as "multithreaded", and that you didn't start adding "ignore libraries" settings on the linker property page.
I don't think an uninstall is warranted yet - you can probably fix things with the proper settings.
Can you post a build log showing the ifort command line, cl command line and link command line?
levicki
Let me clarify what I meant when I suggested reinstall above — Steve is absolutely right, there is a chance to fix it with proper settings and that should be attempted first. But for someone not familiar with setting up those things reinstall might end up being an easier way out of the "mess".
Recreating the solution/project files and making sure that you set all 4 configurations properly (Win32|Debug, Win32|Release, x64|Debug, and x64|Release), would also be among the things I would try before the reinstall.
barakobama
I like to have a fresh start since I feel I messed it up.
But before doing it, I'd like to know what went wrong and get some clues so that I do not make same mistakes again.
Here are my setups for debug and release for 32bit.
===============Release=====================
C/C++ cmd:
/I ".include" /D "WIN32" /D "NDEBUG" /D "_WINDOWS" /D "WOGL" /D "RAINBOW" /D "WIN" /D "_VC80_UPGRADE=0x0600" /D "_MBCS" /FD /EHsc /MT /Fp".Release/mtg230.pch" /Fo".Release/" /Fd".Release/" /W3 /nologo /c /TP /errorReport:prompt
Fortran cmd:
/nologo /include:".include" /include:".include3" /include:".secure3" /define:WIN /define:WOGL /f77rtl /intconstant /iface:cref /module:"$(INTDIR)/" /object:"$(INTDIR)/" /traceback /libs:static /threads /winapp /c
Linker cmd:
/OUT:"C:myapp/mtg.exe" /INCREMENTAL:NO /NOLOGO /LIBPATH:"C:myapp" /LIBPATH:"C:myapp etcdf-3.5.0.win32binlib" /LIBPATH:"C:Program FilesMicrosoft Visual StudioDF98Lib" /LIBPATH:"C:Program FilesMicrosoft Visual StudioVC98Lib" /LIBPATH:"C:Program FilesIntelCompilerFortran9.1IA32lib" /MANIFEST /MANIFESTFILE:".Releasemtg.exe.intermediate.manifest" /NODEFAULTLIB:"libcmt.lib" /SUBSYSTEM:CONSOLE /MACHINE:X86 /ERRORREPORT:PROMPT version.lib wsock32.lib spromeps.lib winmm.lib netapi32.lib odbc32.lib odbccp32.lib opengl32.lib glu32.lib netcdfs.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib "..myappmtg230_lib.lib"
===============Debug=====================
Fortran cmd:
/nologo /Zi /Od /include:".include" /include:".include3" /include:".secure3" /define:WIN /define:WOGL /f77rtl /intconstant /module:"$(INTDIR)/" /object:"$(INTDIR)/" /traceback /libs:static /threads /dbglibs /winapp /c
C/C++ cmd:
/Od /I "C:mtgsrc.230include" /D "WIN32" /D "_DEBUG" /D "_WINDOWS" /D "WOGL" /D "RAINBOW" /D "WIN" /D "_VC80_UPGRADE=0x0600" /D "_MBCS" /Gm /EHsc /RTC1 /MTd /Fp".DEBUG/mtg230.pch" /Fo".DEBUG/" /Fd".DEBUG/" /W3 /nologo /c /ZI /TP /errorReport:prompt
Linker cmd:
/OUT:".debug/mtg230-debug.exe" /INCREMENTAL /NOLOGO /LIBPATH:"C:myapp" /LIBPATH:"C:myapp etcdf-3.5.0.win32binlib" /LIBPATH:"C:mtgsrc.230" /LIBPATH:"C:Program FilesIntelCompilerFortran9.1IA32lib" /MANIFEST /MANIFESTFILE:".DEBUGmtg230-debug.exe.intermediate.manifest" /NODEFAULTLIB:"libcmt.lib" /NODEFAULTLIB:"libc.lib" /DEBUG /PDB:".debug/mtg230-debug.pdb" /MAP:".debugmtg230-debug.map" /SUBSYSTEM:CONSOLE /MACHINE:X86 /ERRORREPORT:PROMPT version.lib wsock32.lib spromeps.lib winmm.lib netapi32.lib opengl32.lib glu32.lib netcdfs.lib odbc32.lib odbccp32.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib "..myappmtg230_lib.lib"
Steven_L_Intel1
I see one problem that may or may not give you trouble - you have CVF folders in the library paths.
In VS, go to Tools > Options > Intel Fortran > Directories. In each of the Executable, Library and Include file settings, delete any entries including "DF98" in the path. Do the same for Tools > Options > Projects > VC++ Directories.
I would also advise removing the DF98 paths from the PATH, LIB and INCLUDE system environment variables (which is how they ended up in the VS paths)
levicki
Steve, and what about:
And:
Should that be included in the project settings or not? No wonder strlen(), sprintf() and such are unresolved.
Steven_L_Intel1
Quite right - those should be removed. My view is that /nodefaultlib is a last-resort thing when you cannot find an alternate solution. The problem is that the linker suggests it in error messages caused by inconsistent library settings.
barakobama
It worked but partially.
I removed libcmt.lib from the "ignore lib" option. Success!!
However, it appears I still need that library when I move the solution file
to another machine and ran it. What could make the difference?
System environment?
1>------ Build started: Project: mtg230, Configuration: Release x64 ------
1>Linking...
1>LIBCMTD.lib(dbgheap.obj) : error LNK2005: malloc already defined in LIBCMT.lib(malloc.obj)
1>LIBCMTD.lib(dbgheap.obj) : error LNK2005: _heap_alloc already defined in LIBCMT.lib(malloc.obj)
1>LIBCMTD.lib(dbgheap.obj) : error LNK2005: calloc already defined in LIBCMT.lib(calloc.obj)
1>LIBCMTD.lib(dbgheap.obj) : error LNK2005: realloc already defined in LIBCMT.lib(realloc.obj)
1>LIBCMTD.lib(dbgheap.obj) : error LNK2005: _recalloc already defined in LIBCMT.lib(realloc.obj)
1>LIBCMTD.lib(dbgheap.obj) : error LNK2005: free already defined in LIBCMT.lib(free.obj)
1>LIBCMTD.lib(dbgheap.obj) : error LNK2005: _msize already defined in LIBCMT.lib(msize.obj)
1>LIBCMTD.lib(dbghook.obj) : error LNK2005: __crt_debugger_hook already defined in LIBCMT.lib(dbghook.obj)
1>LIBCMTD.lib(isctype.obj) : error LNK2005: _isctype_l already defined in LIBCMT.lib(isctype.obj)
1>LIBCMTD.lib(isctype.obj) : error LNK2005: _isctype already defined in LIBCMT.lib(isctype.obj)
1> Creating library C:myapp/mtg64.lib and object C:myapp/mtg64.exp
1>LINK : warning LNK4098: defaultlib 'LIBCMTD' conflicts with use of other libs; use /NODEFAULTLIB:library
1>C:myapp/mtg64.exe : fatal error LNK1169: one or more multiply defined symbols found
1>Build log was saved at "file://c:myapp.230.64bitx64ReleaseBuildLog.htm"
1>mtg230 - 11 error(s), 1 warning(s)
N
Steven_L_Intel1
You have a mix of debug libraries and non-debug libraries.between the C and Fortran projects. These must be the same.
