cannot open msvcrt!
helal53
While trying to compile and link a fortran 77 code using DIANA-9.1 version the following error message is found:
dfcd -MD -STACK:10485760,40960 -NODEFAULTLIB:LIBC.LIB -NODEFAULTLIB:DFOR.LIB -o
nl41.exe
usrmat.obj C:/PROGRA~1/DIANA9~1.2/obj/ap/nl41/nonlin.obj C:/PROGRA~1/DIANA9~
1.2/obj/ap/lb40.lib C:/PROGRA~1/DIANA9~1.2/obj/nl/in41.lib C:/PROGRA~1/DIANA9~1.
2/obj/nl/rd41.lib C:/PROGRA~1/DIANA9~1.2/obj/nl/if41.lib C:/PROGRA~1/DIANA9~1.2/
obj/nl/is41.lib C:/PROGRA~1/DIANA9~1.2/obj/nl/cv41.lib C:/PROGRA~1/DIANA9~1.2/ob
j/nl/st41.lib C:/PROGRA~1/DIANA9~1.2/obj/nl/ix41.lib C:/PROGRA~1/DIANA9~1.2/obj/
nl/rl41.lib C:/PROGRA~1/DIANA9~1.2/obj/nl/lo41.lib C:/PROGRA~1/DIANA9~1.2/obj/nl
/es41.lib C:/PROGRA~1/DIANA9~1.2/obj/nl/ec41.lib C:/PROGRA~1/DIANA9~1.2/obj/nl/d
u41.lib C:/PROGRA~1/DIANA9~1.2/obj/nl/tg41.lib C:/PROGRA~1/DIANA9~1.2/obj/nl/rf4
1.lib C:/PROGRA~1/DIANA9~1.2/obj/nl/lg41.lib C:/PROGRA~1/DIANA9~1.2/obj/nl/lb41.
lib C:/PROGRA~1/DIANA9~1.2/obj/fl/ma40.lib C:/PROGRA~1/DIANA9~1.2/obj/ls/as40.li
b C:/PROGRA~1/DIANA9~1.2/obj/ls/em40.lib C:/PROGRA~1/DIANA9~1.2/obj/ls/ev40.lib
C:/PROGRA~1/DIANA9~1.2/obj/ls/fu40.lib C:/PROGRA~1/DIANA9~1.2/obj/ls/it40.lib C:
/PROGRA~1/DIANA9~1.2/obj/ls/lo40.lib C:/PROGRA~1/DIANA9~1.2/obj/so/so40.lib C:/P
ROGRA~1/DIANA9~1.2/obj/fs/ac40.lib C:/PROGRA~1/DIANA9~1.2/obj/fs/am40.lib C:/PRO
GRA~1/DIANA9~1.2/obj/fs/ef40.lib C:/PROGRA~1/DIANA9~1.2/obj/fs/em40.lib C:/PROGR
A~1/DIANA9~1.2/obj/fs/fl40.lib C:/PROGRA~1/DIANA9~1.2/obj/fs/gm40.lib C:/PROGRA~
1/DIANA9~1.2/obj/fs/ia40.lib C:/PROGRA~1/DIANA9~1.2/obj/fs/rd40.lib C:/PROGRA~1/
DIANA9~1.2/obj/fs/sv40.lib C:/PROGRA~1/DIANA9~1.2/obj/ps/fs40.lib C:/PROGRA~1/DI
ANA9~1.2/obj/ps/sf40.lib C:/PROGRA~1/DIANA9~1.2/obj/pf/ev40.lib C:/PROGRA~1/DIAN
A9~1.2/obj/pf/as40.lib C:/PROGRA~1/DIANA9~1.2/obj/lb/pf40.lib C:/PROGRA~1/DIANA9
~1.2/obj/po/sr40.lib C:/PROGRA~1/DIANA9~1.2/obj/po/wr40.lib C:/PROGRA~1/DIANA9~1
.2/obj/lb/ma40.lib C:/PROGRA~1/DIANA9~1.2/obj/lb/ql30.lib C:/PROGRA~1/DIANA9~1.2
/obj/lb/ge30.lib C:/PROGRA~1/DIANA9~1.2/obj/lb/el30.lib C:/PROGRA~1/DIANA9~1.2/o
bj/lb/aj40.lib C:/PROGRA~1/DIANA9~1.2/obj/lb/dy40.lib C:/PROGRA~1/DIANA9~1.2/obj
/lb/ci30.lib C:/PROGRA~1/DIANA9~1.2/obj/lb/gs30.lib C:/PROGRA~1/DIANA9~1.2/obj/l
b/ds30.lib C:/PROGRA~1/DIANA9~1.2/obj/lb/pd30/lp.lib C:/PROGRA~1/DIANA9~1.2/obj/
lb/pd30/ep.lib C:/PROGRA~1/DIANA9~1.2/obj/lb/pd30/or.lib C:/PROGRA~1/DIANA9~1.2/
obj/lb/pd30/lapack.lib C:/PROGRA~1/DIANA9~1.2/obj/lb/pd30/ls.lib C:/PROGRA~1/DIA
NA9~1.2/obj/lb/pd30/blas.lib C:/PROGRA~1/DIANA9~1.2/obj/lb/pd30/metis.lib C:/PRO
GRA~1/DIANA9~1.2/obj/lb/sc30.lib C:/PROGRA~1/DIANA9~1.2/obj/lb/dc32.lib C:/PROGR
A~1/DIANA9~1.2/obj/lb/bb40.lib C:/PROGRA~1/DIANA9~1.2/obj/lb/po40.lib C:/PROGRA~
1/DIANA9~1.2/obj/lb/ds30.lib C:/PROGRA~1/DIANA9~1.2/obj/lb/gs30.lib C:/PROGRA~1/
DIANA9~1.2/obj/lb/fl44.lib C:/PROGRA~1/DIANA9~1.2/obj/lb/sc30.lib C:/PROGRA~1/DI
ANA9~1.2/obj/lb/dc32.lib C:/PROGRA~1/DIANA9~1.2/obj/lb/gs30.lib C:/PROGRA~1/DIAN
A9~1.2/obj/lb/fl44.lib C:/PROGRA~1/DIANA9~1.2/obj/lb/cx40.lib C:/PROGRA~1/DIAN
A9~1.2/obj/fgv7.0/dumgui.obj femgv7.lib dumsubs.lib dumtran.lib spromeps.lib sen
tc.lib libhasp.lib
C:/PROGRA~1/DIANA9~1.2/obj/lb/cx40.lib advapi32.lib user32.lib
Intel Fortran Compiler for 32-bit applicatio ns, Version 9.1 Build 20060323
Z Package ID: W_FC_P_9.1.024J
Copyright (C) 1985-2006 Intel Corporation. All rights reserved.
Fatal error cannot open "MSVCRT"
ifort: error: problem during multi-file optimization compilation (code 1)
rcsmake: *** [nl41.exe] Error 1
rcscat UM_ap_nl41 | flmakefl -w > C:DOCUME~1huiyanLOCALS~1TempUMa00644
Diana abort routine called
SEGPATH extended to ".;C:/PROGRA~1/DIANA9~1.2/binseg"
Make segment failed
Trying to close things.
DIANA JOB 3200 finished
Any body can help me to overcome this problem?
thanks
What's the value of the LIB environment variable? How did you start this command prompt session?
The inclusion of the -nodefaultlib switches worries me - especially the one for DFOR.LIB. If you have references to that, you have bigger troubles.
helal53
Dear,
Now, How can I proceed?
thanks
helal53
I started the command prompt in the following way:
C:Documents and Settingshuiyan>diana initia
diana: working directory is C:Documents and Settingshuiyan
diana: input file is initia.dat
diana: command file is initia.com
diana: output file is initia.out
diana: filos file is diana.ff
Then the error message is found.
helal
I don't know this "diana", and you have already started the command session by this time. What version of Microsoft Visual Studio do you have installed?
Before you do the "diana" command, do this:
"C:Program FilesIntelCompilerFortran9.1IA32Binifortvars.bat"
(with the quotes), then try building.
helal53
Dera Steve,
Ihave installed MVS2005.
I have got the following results using the following command:
C:Program FilesIntelCompilerFortran9.1IA32Bin>ifortvars.bat
Intel Visual Fortran Compiler 9.1.024 Build Environment for 32-bit applicatio
ns
Setting environment for using Microsoft Visual Studio 2005 x86 tools.
It confirms the setting of enivriomental variables.
Best regards
Helal
helal53
Dear Steve,
I have installed MVS 2005.
I have got the following result while using the command:
ns
Please give me someadivces in this regard!
Best regards
Helal
Ok - now that you ran ifortvars.bat, do a build and show me the output of the build commands. I want to see the call to ifortvars.bat and then the "diana" build with the exact ifort commands being used.
Can you build a "hello world" program with ifort from this command prompt?
helal53
dear Steve,
The output of "Hello World program"is given below:
C:Documents and Settingshuiyan>ifort bonjour.f
Intel Fortran Compiler for 32-bit applications, Version 9.1 Build 20060323
Microsoft Incremental Linker Version 8.00.50727.42
Copyright (C) Microsoft Corporation. All rights reserved.
-out:bonjour.exe
-subsystem:console
bonjour.obj
C:Documents and Settingshuiyan>bonjour.exe
HELLO WORLD
Best regards
Helal
Helal,
That shows that the compiler is working. Please show the output from the build with "diana" that does not work. Make sure all the ifort commands are shown.
helal53
Dear Steve,
Thanks a lot for your cooperation.
Now, the ouput from the build with Diana is given below:
I have used user-supplied subroutine in Diana analysis.
C:Documents and Settingshuiyan>ifortvars.bat
ns
C:Documents and Settingshuiyan>diana visco
diana: input file is visco.dat
diana: command file is visco.com
diana: output file is visco.out
BINSEG set to "."
dfcd -c -MD usrmat.f
rm -f nl41.exe
nl41.exe ---------------------------------------
usrmat.obj C:/PROGRA~1/DIANA9~1.2/obj/ap/nl41/nonlin.obj C:/PROGRA~1/DIANA9~1.2/obj/lb/cx40.lib advapi32.lib user32.lib
/LARGEADDRESSAWARE /STACK:10485760,40960 /NODEFAULTLIB:LIBC.LIB /NODEFAULTLIB:DF
OR.LIB
-out:nl41.exe
-subsystem:console
usrmat.obj
C:PROGRA~1DIANA9~1.2objlbcx40.lib
femgv7.lib
dumsubs.lib
dumtran.lib
spromeps.lib
sentc.lib
libhasp.lib
advapi32.lib
user32.lib
C:/PROGRA~1/DIANA9~1.2/bin/instal.exe nl41.exe ./ap/nl41.exe
Microsoft Manifest Tool version 5.2.3790.2014
Copyright (c) Microsoft Corporation 2005.
mt -outputresource:./ap/nl41.exe;1 -manifest nl41.exe.manifest
rcscat UM_ap_nl41 | flmakefl -w > C:DOCUME~1huiyanLOCALS~1TempUMa02740
forrtl: severe (157): Program Exception - access violation
Image PC Routine Line Source
nl41.exe 004010FE Unknown Unknown Unknown
nl41.exe 0049EBE8 Unknown Unknown Unknown
nl41.exe 0043AC20 Unknown  ; Unknown Unknown
nl41.exe 0042CE5B Unknown Unknown Unknown
DIANA JOB 3844 finished
Best regards
Helal
Now you have a completely different problem. The program builds successfully, but gets an error at run-time. All I can do at this point is direct you to my article on access violation and have you try to debug the problem. It could be that you have incorrectly coded your subroutine so that its arguments do not match what the caller is supplying.
helal53
Steve,
Thanks a lot for cooperation.
I have got the problems and solved. Now, its working with user-supplied subroutine.
helal
helal,
I am glad to hear it.
arshiakhafan
I want to use "user supplied subroutines in diana9.2 on the windows xp.it need installation intel visual fortran compiler.I have problems about interface DIANA and intel fortran compiler.
It's question6 in "help Dianaanalysis examplesgetting started with user-supplied subroutines" that mentioned bellow:
6. Run a simple Diana job with this subroutine. Use a command _le that
will compile subroutine ELSGUS.
Answer:
To run a Diana job you have to create a command _le. In this case
it can be a very simple one: just initialize the filos _le and de_ne the
user-supplied subroutine. For instance:
initia.com?
*FILOS
INITIA
*FORTRAN
TAKE "elsgus.f"
*END
elsgus.f?
SUBROUTINE ELSGUS( EPS, NSTR, TSIG )
C........................................Copyright (c) 2007 TNO DIANA BV
INTEGER NSTR
DOUBLE PRECISION EPS(NSTR), TSIG(NSTR)
C
PRINT *, 'My own ELSGUS routine'
C
END
Now run Diana with this command _le:
diana initia
This run will build your own executable for Module nonlin. the program asked me for a .dat file.what is it?
the error messages received that mentioned bellow:
rcsmake:failed to remake makefile 'c:docume~1A9056~1.KHALOCALS~1TempUMa00680' has modification time in the future
rcsmake:Failed to remark makefile 'c:docume~1A9056~1.KHALOCALS~1TempUMa0068 '
dfcd c MD elsgus.f
Intel Fortran compiler for 32-bit applications,version 9.0 build 20050912 z package ID:W-FC-C-9.0 0.024
Copyright 1985-2005 Intel Corporation.All rights reserved.
Rm f nl41.exe
Dfcd MD STACK:10485760,40960 NODEFAULTLIB:LIBC.LIB NODEFAULTLIB:DFOR.LIB O NL41.EXE
Elsgus.obj C:/PROGRA~1/DIANA~1.2/obj/ap/nl41/nonlin.obj C:/PROGRA~1/DIANA9~1.2/obj/ap/lb40.lib C:/PROGRA~1/DIANA9~1.2/obj/nl/in41.lib C:/PROGRA~1/DIANA9~1.2/obj/nl/rd41.lib
C:/PROGRA~1/DIANA9~1.2/obj/nl/iS41.lib
C:/PROGRA~1/DIANA9~1.2/obj/nl/CV41.lib
C:/PROGRA~1/DIANA9~1.2/obj/nl/st41.lib
C:/PROGRA~1/DIANA9~1.2/obj/nl/rl41.lib
C:/PROGRA~1/DIANA9~1.2/obj/nl/es41.lib
C:/PROGRA~1/DIANA9~1.2/obj/nl/du41.lib
C:/PROGRA~1/DIANA9~1.2/obj/nl/rf41.lib
C:/PROGRA~1/DIANA9~1.2/obj/nl/lb41.lib
C:/PROGRA~1/DIANA9~1.2/obj/f1/ma40.lib
C:/PROGRA~1/DIANA9~1.2/obj/ls/as40.lib
C:/PROGRA~1/DIANA9~1.2/obj/ls/lo40.lib
C:/PROGRA~1/DIANA9~1.2/obj/fs/ac40.lib
C:/PROGRA~1/DIANA9~1.2/obj/fs/ef40.lib
C:/PROGRA~1/DIANA9~1.2/obj/fs/fgv7.0/dumgui.obj femgv7.lib dumsubs.lib dumtran.lib spromeps.lib sentc.lib libhasp.lib
Intel Fortran Compiler for 32-bit applications,version9.0 Build 20050912
Z Package ID: W_FC_C_9.0.024
Copyright 1985-2005 Intel Corporation. All rights reserved.
Fatal error cannot open"msvcrt"
Ifort:error.problem during multi-file optimization compilation
Rcsmake:***[nl41.exe] Error 1
Rcscat UM-AP-NL41 :flmakefl w> C:DOCUME~1A9056~1.KHALOCALS~1TEMPUMa00680
SEGPATH extended to ";c:/PROGRA~1/DIANA9~1.2/binseg"
Make segment failed
DIANA JOB 1872 finished
thanks
arshiakhafan
Answer:
initia.com?
*FILOS
INITIA
*FORTRAN
TAKE "elsgus.f"
*END
elsgus.f?
INTEGER NSTR
C
C
END
diana initia
dfcd c MD elsgus.f
Rm f nl41.exe
Make segment failed
thanks
email:[email protected]
