29487 Discussions
cannot see the value of an allocatable array of derived type variable in VS debugger
pan__li
I am using VS2012, and my code is as below, also the file is attached.
my problem is that I cannot see the 'v' component (that is allocatable) of x array at a break point in subroutine sr2, even though I can print it.
it is interesting that we have no problem in seeing the 'a' component of x array.
what is the reason? how to fix it?
Thanks!
code:
    MODULE dtype
    IMPLICIT NONE
    type dt
        real*8, Dimension(:),   allocatable :: v
        real*8 :: a
    end type dt
    end Module dtype
    subroutine  sr1(x)
    use dtype
    implicit none
    type(dt) x
    allocate(x%v(3))
    x%v=[1.0, 2.0, 3.0]
    end subroutine sr1
    subroutine  sr2(x)
    use dtype
    implicit none
    type(dt) x(3)
    call sr1(x(1))
    call sr1(x(2))
    call sr1(x(3))
    write(*,*) 'break point here. We cannot see the value of v component of x array in debugger, but we can print it'
    write(*,*) x(1)%v
    end subroutine sr2
    program main
    use dtype
    implicit none
    type(dt) x(3)
    call sr2(x(1:3))
    write(*,*) x(1)%v
    pause
    end program main
