cannot use IMSL
Intel_C_Intel
Hi. I just installed Intel Visual Fortran 10.1 for Windows with IMSL. I have a trouble using IMSL. When I run a program that has USE MSIMSL (which worked fine with Compaq Visual Fortran I used to use), I get an error :
Error in opening the compiled module file. Check INCLUDE paths. [MSIMSL]
Please help, and let me know how I could solve the problem. It must be something simple, but I have no clue...
Thanks a million.
It is simple - Visual Numerics dropped the MSIMSL module from their package. Just change that to USE NUMERICAL_LIBRARIES and you should be ok. Also, because IMSL in Intel Fortran has more library types, you need to change the way you specify the libraries.
Add the lines:
include 'link_fnl_static.h'
!DEC$ OBJCOMMENT LIB:'libguide.lib'
to one of your sources and make sure that the paths to the IMSL LIB and INCLUDE folders are entered into Tools > Options > Intel Fortran > Directories > Libraries (and Include Files) respectively.
For more information, read the section on using IMSL in the Building Applications > Using Libraries > Using IMSL section of the on-disk documentation.
Intel_C_Intel
Hi
I try the following code:
INCLUDE
'link_fnl_static.h'
program
main
USE
OWFRQ_INT
USE
UMACH_INT
IMPLICIT NONE
INTEGER
K, NOBS
PARAMETER
(K=10, NOBS=30)
INTEGER
NOUT
REAL
DIV(K), TABLE(K), X(NOBS)
DATA
X/0.77, 1.74, 0.81, 1.20, 1.95, 1.20, 0.47, 1.43, 3.37, &
2.20, 3.00, 3.09, 1.51, 2.10, 0.52, 1.62, 1.31, 0.32, 0.59, &
0.81, 2.81, 1.87, 1.18, 1.35, 4.75, 2.48, 0.96, 1.89, 0.90, &
2.05/
CALL
UMACH (2, NOUT)
CALL
OWFRQ (X, K, TABLE, DIV=DIV)
WRITE
(NOUT,99999) DIV, TABLE
99999
FORMAT (' Midpoints: ', 10F5.2, /, ' Counts: ', 10F5.0)
END
I figure out "!DEC$ OBJCOMMENT LIB:'libguide.lib'" from this post.
I have two questions:
1. I open 'link_fnl_static.h' and find there are similar lib files. I am wondering why you don't put the second line in it.
2. In the Help: Building Applications > Using Libraries > Using IMSL section. There are eight header files to be INCLUDEd. I don't know which one should I INCLUDE.
3. I intentionally INCLUDE all of them and find:
Error1 fatal error LNK1104: cannot open file 'mpi.lib'LINK
Chien-Hui
Intel_C_Intel
I am also curious about whatthe mod files are contained in some lib file, e.g. 'libguide.lib'.
Thank you.
The .h file was created by Visual Numerics. In fact, I recommended to them that they include libguide.lib in the file, but their recommendation to users is to add /Qopenmp to the compile options. As /Qopenmp has side-effects you may not want, such as making all variables automatic, I prefer the OBJCOMMENT directive to pull in the OpenMP library libguide.lib
Do not include all of the header files. Normally, the one you want is link_fnl_static.h. If you don't understand the descriptions of the others, stick with that one. The other variants may link to the DLL libraries (_shared) or use Intel MKL to speed up some operations (_hpc).
