29648 Discussions
catastrophic error: **Internal compiler error: segmentation violation signal raised**
nnemec
I am using ifort 11.1 20100414
Compiling the source file below with
ifort -O3 -check bounds -c pbc_lists_X.f90
gives the error message :
: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for pbc_lists_X.f90 (code 3)
Greetings,
Norbert Nemec
PS: Is there any obvious place to report internal compiler errors? These are obvious bug reports and as such very different from user support issues.
----- pbc_lists_X.f90 -----
module pbc_lists
implicit none
integer,public :: n_periodic, n_atoms
logical,public :: transport_calculation, transport_lead_calculation
contains
subroutine evaluate_number_of_supercells_needed_in_periodic_systems
implicit none
real*8 :: lenght_of_lattice_vector_l
real*8, dimension(3,3):: A
integer :: i_atom, i_latt, i_latt_2
if( transport_lead_calculation .or. transport_calculation)then
do i_latt = 1,3
end do
end if
if(transport_lead_calculation .or. transport_calculation)then
do i_atom = 1,n_atoms
end do
end if
do i_latt = n_periodic+1,3,1
do i_latt_2 = 1,i_latt-1,1
lenght_of_lattice_vector_l = (dot_product(A(:,i_latt_2),A(:,i_latt_2))) !
A(:,i_latt) = A(:,i_latt) - A(:,i_latt_2)* &
dot_product(A(:,i_latt),A(:,i_latt_2)) / lenght_of_lattice_vector_l
end do
end do
end subroutine evaluate_number_of_supercells_needed_in_periodic_systems
end module pbc_lists
mecej4
The error does not occur with the 11.1, Update-7 (20100806) version.
There is a new compiler release (Release 12) expected this month.
I have seen frequent postings about compiler errors in this Forum, and the Intel people have responded promptly to those postings. The majority of such errors are fixed in the next update of the compiler, so I tend to assume that this forum is a fine place for reporting bugs.
