29651 Discussions
catastrophic error: **Internal compiler error
m_memoli
Dear all,
I have a problem with Intel Fortran compiler 11.1 and the simple following code.
program loop
use omp_lib
call omp_set_num_threads(14)
!$omp parallel
write(*,*) 'Number of threads = ', omp_get_num_threads()
10 i = 1
goto 10
!$omp end parallel
end program
When I try to compile using ifort -openmp -o loop loop.f the compiler returns the following error:
: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for loop.f (code 3)
When i try with Intel Fortran compiler 10.1 i have no error.
Thanks to all.
Kevin_D_Intel
Thank you for the convenient reproducer. As you probably determined, the internal error relates to the goto statement. The error still occurs with our upcoming next major release. I reported this to Development and will update this post as I learn more.
(Internal tracking id: DPD200162544)
(Resolution Update on 02/21/2011): This defect is fixed in the Intel Fortran Composer XE 2011 Update 2 (2011.2.137 - Linux)
Kevin_D_Intel
