29487 Discussions
catastrophic error for expressions involving polimorphic operators
Salvadore__Francesco
I am experiencing problems using expressions with polymorphic objects and operators.
I managed to reproduce the error in a small code which I post below.
Basically the type ta is abstract with =, +, * (real*obj) deferred operators while type tb implements them. While a+b and k*a work, if I try to do k*(a+b) it cannot compile reporting internal compiler error. I cannot understand the reason of such behavior.
module ma
    type, abstract :: ta
        contains
            procedure(abs_ass),     private, deferred :: ass
            procedure(abs_add),     private, deferred :: add
            procedure(abs_realmul), private, deferred, pass(a) :: realmul
            generic, public :: assignment(=) => ass
            generic, public :: operator(+) => add
            generic, public :: operator(*) => realmul
    endtype
    abstract interface
        subroutine abs_ass(a, b)
            import :: ta
            class(ta), intent(inout) :: a
            class(ta), intent(in) :: b
        end subroutine abs_ass
        function abs_add(a, b) result(r)
            import :: ta
            class(ta), intent(in) :: a, b
            class(ta), allocatable :: r
        end function abs_add
        function abs_realmul(k, a) result(r)
            import :: ta
            real, intent(in) :: k
        end function abs_realmul
    end interface
end module ma
module mb
    use ma
    type, extends(ta) :: tb
        real :: x
        contains
            procedure, private :: add
            procedure, private :: ass
            procedure, private, pass(a) :: realmul
    endtype
contains
    subroutine ass(a, b)
        class(tb), intent(inout) :: a
        select type(b)
           type is(tb)
               a%x = b%x
           class default
               print*,"Error"
        endselect
    end subroutine ass
    function add(a, b) result(r)
        class(tb), intent(in) :: a
        allocate(tb :: r)
        select type(b)
           type is(tb)
               select type(r)
                   type is(tb)
                       r%x = a%x + b%x
               end select
           class default
               print*,"Error"
        endselect
    end function add
    function realmul(k, a) result(r)
        allocate(tb :: r)
        select type(r)
           type is(tb)
               r%x = k * a%x
           class default
               print*,"Error"
        endselect
    end function realmul
end module mb
program mt
    use ma
    use mb
    class(ta), allocatable :: va1, va2, va3
    allocate(tb :: va1)
    allocate(tb :: va2)
    allocate(tb :: va3)
    select type(va1)
        type is(tb)
            va1%x = 10.
    endselect
    select type(va2)
        type is(tb)
            va2%x = 20.
    endselect
    !IT WORKS va3 = va1 + va2
    !IT WORKS va3 = 3.*va1
    ! CATASTROPHIC ERROR
    va3 = 1.*(va1 + va2)
    select type(va3)
        type is(tb)
            print*,"it should be 30: ",va3%x
    endselect
end program mt
Francesco
Thanks for the report. I can reproduce this in 16.0.3 but the 17.0 compiler, due out later this year, reports:
U671994.f90(99): error #6633: The type of the actual argument differs from the type of the dummy argument.
This is clearly wrong as well, but at least no internal compiler error! I will send this on to the developers.Issue ID is DPD200413156.
We're still working on this, but we discovered that there's an error in your source that the current compiler doesn't detect - our development version does.
The deferred bindings in type ta are marked private, this makes them inaccessible when type tb extends type ta. This was clarified in interpretation F08/0052 part of F08 Corrigendum 1.
Thanks for the support. Any news on the compiler version fixing the problem?
Francesco
Kevin_D_Intel
As Steve noted, the internal compiler error you experienced with the 16.0 compiler is fixed in the latest 17.0 compiler release; however, the 17.0 compiler issues the error note in post #2. There is no fix currently available for that error.
To avoid the internal error you need to upgrade to 17.0, but to avoid the error in post #2 still requires a source code workaround similar to what is noted at source lines 96-97 of the test case. Rewriting line 99 as noted below compiles successfully with the latest 17.0 update 1 compiler.
   va3 = va1 + va2
   va3 = 1.*va3
I inquired with the developer for a current status of a fix for the error in post #2 and will post again with any update that I receive.
Stefano_Zaghi
Dear all,
I have just joined the 2018 beta testing initiative and I can confirm that also the parallel studio xe 2018 beta has the same bug, here my log
┌╼ stefano@zaghi(01:21 PM Thu Apr 13) desk {intel-18.0.0.beta - Intel Parallel Studio XE 2018.0.0 beta}
├───╼ ~/fortran/compilers_bug/intel_abstract_types_operators/salvadore 7 files, 40Kb
└──────╼ ifort abstract_types_operator-salvadore-mt.f90
abstract_types_operator-salvadore-mt.f90(20): error #6633: The type of the actual argument differs from the type of the dummy argument.
compilation aborted for abstract_types_operator-salvadore-mt.f90 (code 1)
My best regards.
Kevin_D_Intel
The internal tracking id linked to this case (DPD200413156) is not fixed yet and I have not heard back from Development on the current status. I added another note re: 18.0.
(Internal tracking id: DPD200413156)
